  • July 19, 2025, 02:38:30 AM
Author Topic: Ink lines on Iron ON Film  (Read 1257 times)
Offline James Mills
« on: September 10, 2009, 10:27:45 PM »
Didn't want to highjack the other thread.  Is there a way to add ink lines to an iron on finish (ala Monocote)?  I plan to clearcoat with automotive clear.
James
AMA 491167
Offline Crist Rigotti
Re: Ink lines on Iron ON Film
« Reply #1 on: September 11, 2009, 06:27:32 AM »
I use regular Monokote that I cut in 1/32 wide strips.  Then I iron them down with a mid heat setting.
« Reply #2 on: September 11, 2009, 08:26:00 AM »
Take the finest sandpaper or steel wool and scuff up the surface.  It works but, you have to over coat everything.  DOC Holliday
Offline "Big Art"
« Reply #3 on: September 11, 2009, 09:24:40 AM »
Hello James
We always used a pencil never a pen. Go to an art store and purchase a pencil # 8008. This pencil sharpened to a fine point will do the job. It writes on glass, plastic and wipes off with a damp paper towel if a mistake is made. Keep the point fine. we always thought the pencil was a softer line which was more realiistic than the ink.
I cannot send any photos as soon as son returns desk top I will send you photos, if you want.
"Big Art"
« Reply #4 on: September 11, 2009, 09:26:14 AM »
Rapidograph makes an ink for writing on "film".  If the surface is really clean it seems to work fine.  It's pretty much available any place you can buy Rapidograph pens--which isn't a whole lot of places since the advent of computerized drawing.
Gotta be clearcoated, of course.
Ted Fancher
« Reply #5 on: September 11, 2009, 04:23:56 PM »
Ted Fancher
Pelican "Green Label" is formulated for film also and works well Available at most art supply and drafting shops....Like Ted says gotta be clearcoated.
Offline corey mckenzie
« Reply #6 on: September 11, 2009, 06:56:01 PM »
be sure to use a flex agent in the automotive clear or you might have some cracks due to engine vibration . i learned that the hard way
