  • July 10, 2025, 05:23:28 AM
Author Topic: Ink Lines  (Read 2818 times)
Offline Chuck Feldman
Ink Lines
« on: September 10, 2009, 05:09:02 AM »
What kind of pen or pen's do you use.
Chuck Feldman
AMA 15850
Offline Bootlegger
Re: Ink Lines
« Reply #1 on: September 10, 2009, 09:21:25 AM »
   I think that it is Top Flight that makes the ones that I use, and yes I do like them..
                  I hope that this helps......
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dick Byron
  • Vendor
Re: Ink Lines
« Reply #2 on: September 10, 2009, 10:34:19 AM »
Rapidograph pens. Look in your local drafting supply store or e bay.
Offline Claudio Chacon
Re: Ink Lines
« Reply #4 on: September 10, 2009, 11:58:42 AM »
Rapidograph pens have been my favorite for years!
Re: Ink Lines
« Reply #5 on: September 10, 2009, 12:02:23 PM »
Like Claudio I use the Sakura Pigma archival pens. Work pretty well and don't bead up.
Offline Roger Vizioli
  • CLiner
Re: Ink Lines
« Reply #6 on: September 10, 2009, 06:11:31 PM »
Chuck,
There are many retired Grumman engineers and draftsmen in the Stuart and Ft Pierce area.
They grew up using Rapidograph pens.
Find one, and ask if he or his buddies have any they want to part with.
Roger V.
Merritt Island
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Tom Niebuhr
Re: Ink Lines
« Reply #7 on: September 10, 2009, 09:10:55 PM »
Rapidograph pens are the way for black panel lines..
Testors used to have a paint pen available in several colors, but they have been replaced by a narrow brush type pen that is too wide.
I have an applications that I need red lines for. Has anyone tried dope in a wide rapidograph?
AMA 7544
Offline Norm Faith Jr.
Re: Ink Lines
« Reply #8 on: September 10, 2009, 09:37:02 PM »
Fine point "Sharpie."
Norm H^^
Circlepilot   AMA9376
Re: Ink Lines
« Reply #9 on: September 10, 2009, 10:09:40 PM »
Problem with the fine point Sharpies is, they tend to fade in the sun over time. Or at least that's been my experience.
Online Lauri Malila
Re: Ink Lines
« Reply #10 on: September 11, 2009, 10:05:10 AM »
 Hi.
 Rotring Rapidograph's have a single-use ink reservoir. They can be re-filled using a pipette with a long, thin tube but it can get messy. I prefer Rotring Isograph pens, they are similar to Rapido's but with a reservoir that is designed to be re-filled.
 Just make sure that you use the "MF" ink, ment for plastic drafting film. Even then the adhesion is not allways the best, I've found that a homeopatic amount (add with  tip of a pin to ink reservoir) of dishwashing liquid is enough to kill the surface tension. L
Re: Ink Lines
« Reply #11 on: September 11, 2009, 10:36:45 AM »
I've had "sharpie lines" (black) under "auto clear" for three years now and they still look the same as when applied. H^^
Norm
Circlepilot   AMA9376
