  • July 14, 2025, 03:36:18 AM
Author Topic: ink line pens  (Read 2671 times)
Offline Greg Hart
ink line pens
« on: January 27, 2014, 11:16:08 AM »
I need some good quality at a good price white ink, and black ink fine line ink pens. Can someone lead me to where are the one's that work great under Brodak dope?
BUY A UKEY AND LEARN
Re: ink line pens
« Reply #2 on: January 27, 2014, 12:58:47 PM »
Again
Don't know about but I picked up a pen at Office Depot and it did not break the piggy bank and worked great. Do a search here and maybe find the picture I posted.
Offline Greg Hart
Re: ink line pens
« Reply #3 on: January 27, 2014, 03:04:47 PM »
I just can't find white  ???
Online RC Storick
Re: ink line pens
« Reply #4 on: January 27, 2014, 04:09:13 PM »
Re: ink line pens
« Reply #5 on: January 27, 2014, 05:55:48 PM »
I'm looking too, for a gray one to make the panel lines and rivets on my Yak-9. I hope the clear Lusterkote is friendly with the marker ink and doesn't make it spread or run.
No luck at Hobbytown USA yesterday, but I did get everything for my control linkages. She's finally getting there. I've never been so meticulous on a build. It's all y'all's fault! Thanks for inspiring me to turn up my game.
Rusty
Re: ink line pens
« Reply #6 on: January 29, 2014, 03:17:09 PM »
Why not just use Brodak (or Sig) White Dope.  It works fine!
I use kooinoor pens and just fill them with white dope instead of ink.
Re: ink line pens
« Reply #7 on: January 29, 2014, 03:58:39 PM »
I was thinking about it while working on the plane today and am thinking, since I'm going to spray clear over flat white paint, maybe a drafting pencil is best for my panel lines and rivets.
Re: ink line pens
« Reply #8 on: January 29, 2014, 05:12:55 PM »
I'd be very careful about pencil.  Pencil lead contains waxes and nothing likes to stick very well over wax.
Randy cuberly
Offline Mike Keville
Re: ink line pens
« Reply #9 on: January 29, 2014, 05:32:41 PM »
Lines and shading on this 1/2A twin were done with art pencils, topped with satin polyurethane.  Worked very well.
Offline Paul Wescott
Re: ink line pens
« Reply #10 on: January 30, 2014, 11:13:43 AM »
Paasche the maker of pretty good airbrushes has a special version for drawing inklines called a flow pencil.  It's basically a gravity powered technical pen (tech pen) just like a Koh-i-noor, except probably allows more flow from the top-mounted tank out throught the nib.  Plus it sounds like it is pretty easy to clean, maybe more so than a tech pen.  It comes standard with a 1/32" nib and you can also buy 1/64" (Wow! Must be for 1/2A), 3/64", and 1/16" nibs.
The links below are a couple of different sources at $40-$50.  The image is something I screen-grabbed from a newsletter I read a while back:
http://www.handsontools.com/Paasche-FP-132-Flow-Pencil-Striping-Applicator-Gravity-Feed_p_4155.html
http://www.rexart.com/product2250.html
Paul W.
Re: ink line pens
« Reply #11 on: January 30, 2014, 12:40:00 PM »
Since I have the wooden holders that are painted with all that I've used to apply the finish so far to the flaps and stab etc., I'll use them as a test piece with some markings from different pencils and see what happens when I spray the clear on.
Rusty
Re: ink line pens
« Reply #12 on: January 30, 2014, 02:00:47 PM »
ink for film http://www.draftingsteals.com/koundrinkwh7.html
  Is there some trick to using the white ink?  I have no problem with the black, works like regular ink. The white seems to want to form a film of some sort as it comes out of the pen, and I get a big clump right at the nib in no time at all.
    I use Testors solvent-type paint for anything but black, that always works. The one that is missing from the regular inks is an acceptable silver.
