  • July 07, 2025, 06:38:40 AM
Author Topic: witch wich is witch  (Read 2615 times)
Offline roger
witch wich is witch
« on: June 13, 2008, 11:33:24 AM »
any body ever here of this plane? from the late 50s it was the "wicked witch" just like to know.. ???
Alan Hahn
Re: witch wich is witch
« Reply #1 on: June 13, 2008, 11:56:43 AM »
Which? ;D
Offline Just One-eye
  • Another Old Fart
« Reply #2 on: June 13, 2008, 12:12:02 PM »
Looked somewhat like an F86, and there was a similar looking kit out, as well (Jetco, perhaps).
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
« Reply #3 on: June 13, 2008, 03:11:03 PM »
Yep, built one from planes back around 54! Trike gear and yes looked a lot like the F-86D.Had loots of fun with it.
Gene
 y1 %^@
« Reply #4 on: June 13, 2008, 06:59:05 PM »
The Wicked Witch was published in the Nov 55 issue of Air Trails Hobbies for Young Men.  As mentioned above, the fuselage design was inspired by the F-86D.  Trike gear.  It had a tapered, unswept wing and horizontal tail.  56 inch span.
Plans are listed on Stuka Stunt.
« Reply #5 on: June 13, 2008, 07:43:14 PM »
There was a pic of a Wicked Witch in Stunt News a few years ago. I always wondered about it's "stuntability". Anyone actually flown one? Is it worth building for the classic event?
« Reply #6 on: June 14, 2008, 12:41:54 PM »
I have not seen one nor have I seen one fly.  The plans show a Fox 35.   (Remember, this was in 1955 when the thing was published.)  With the 56 inch wing, it appears to have a nice bit of area and the airfoil looks right as far as thickness and fairly blunt leading edge.  It looks like it would build heavy with the structure shown for the fuselage and wing.  I would think the amount of wood used could be reduced somewhat.  If the weight is kept within reason and with a good 40 or even a 46, there would be nothing wrong with the performance of this airplane.
There are a lot of places where structural weight could be reduced, like using 1/32" doublers instead of 1/16". This wold work up to be a really attractive Classic ship with its similarity to the F-86D  Keeping the weight to a reasonable limit would be the challenge to make this a decent flying airplane.
« Reply #7 on: June 14, 2008, 04:02:19 PM »
Mr. Trostle, thanks for the info.
Offline Bill Gruby
« Reply #8 on: June 14, 2008, 04:03:25 PM »
 Can someone scan a picture of this one please?
  "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #9 on: June 14, 2008, 10:52:02 PM »
Best I can do. From the May/June '95 Stunt News.
Offline gary tultz
« Reply #10 on: June 15, 2008, 10:00:01 PM »
Designed and built by Don Hoag, Columbus Ohio. I sent my original ATHYM Plans to Randy Ryan in Michigan. He might send them to you.
« Reply #11 on: June 17, 2008, 03:54:30 AM »
I have the magazine, plans and started a fuselage about 15 years ago! :-D
Mr. Hoag was a YMCA director, and he modeled the plane after an all red F-86D.  Wesley Smith from Delaware was very keen on this plane and we corresponded about it for a long time after we met at the '93 NATS.
Everything Keith says is true, but he left out the part of the large asymmetry in the wings, similar to the *Original* Nobler.  I would use a LA 46, maybe a ST 456, or a Aero Tiger 36 in it. (of course a really high tech 40 wouldn't hurt! )
Mongo
Offline wmiii
« Reply #12 on: June 17, 2008, 03:19:37 PM »
 I would also note, that the nose is rather short, getting a suitable tank installed might be a bit of a problem.
 Walter
walter menges
« Reply #13 on: June 19, 2008, 09:31:01 AM »
 Walter
Hi Walter,
I am sure you will have to notch the LE to get a tank in big enough for todays pattern using mostr of the engines we use.  Or do like Al Rabe and make square tanks.  ;D
Mongo
