  • July 19, 2025, 04:25:24 PM
Author Topic: ...Info please...  (Read 1354 times)
Offline Bootlegger
...Info please...
« on: September 11, 2007, 11:16:19 AM »
 :!  Guy's Yesterday I was runnin' my RO Jett 40 rear exhaust with a 11.5x4 APC prop on 10% 11&11 oil and started with 5 oz of fuel. Timed it at better than 9 minutes, cut to 4 1/2 oz same fuel got over 8 min then 4 1/4 ox got over 7 min.
  Is this normal ?  The engine is broken, or has about 1 hr to 1.5 hr on the bench.
  I am not complaining, but I sure am curious.???
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline captcurt
Re: ...Info please...
« Reply #1 on: September 11, 2007, 12:10:16 PM »
Thats not far off my own experience with the BSE 40 on a header muffler in my old Vector40.  I ran with a filter on mine also.  It would burn more if the venturi was opened up.
I ran my mostly 4 stroking along and breaking nicely into a two stroke up high.  10% was used when it got hot only--most of the time it was 5%.
For high density altitute days, try an apc 11 x 5.  It seems to give alot of bite in the hot humid days. (Thanks to Dave Hemstraught)
Curt
Offline Bootlegger
« Reply #2 on: September 11, 2007, 01:46:31 PM »
 Kurt,
 Thanks for the response. I failed to say that I'm running a muffler instead of a pipe,and that the tach was showing in the range of 9300--9550 rpm.
  It still has the break in plug so that will be changed to a T bolt lont w/idle bar when it goes in the model.
 I also don't run with muffler pressure instead open to the atmosphere on the vent.
  I'm looking forward to getting it installed in the new model.
 Again thanks for the info    #^
Gil Causey
AMA# 6964
« Reply #3 on: September 11, 2007, 02:28:36 PM »
Wish my Ton Lay OS46VF had that kind of gas milage. I had to put a "wart" on the front of the tank to extend the capacity to a bit over 7oz to have enough fuel to finish the pattern. This with a .270 venturi. Man, what does Tommy do to these things? Sure has plenty of power. That's certain. I can tell you I was pretty shocked when I filled the tank (6.5oz capacity) and ran out of fuel in the overheads. Yeow!
Offline Bootlegger
« Reply #4 on: September 11, 2007, 02:39:57 PM »
 What about restricting the venturi by about .010 and see what it does for power and milage ?? Might help both ... H^^
Gil Causey
AMA# 6964
Offline captcurt
« Reply #5 on: September 12, 2007, 07:46:18 AM »
With the four pitch prop, you might need to run it a bit faster RPM in a plane so that will get you down a little on fuel.
Mine was the small insert muffler put into the end of the header--simple and effective.
And the engine will continue to get better as it fully seats in--perhaps over a couple of hundred flights.
Randy:  Wow!  7 oz!!  Well, around here we say that fuel burned is horsepower made.  One of our group just put a 9 oz tank into his PA75 setup.
Curt
