  • June 29, 2025, 12:08:45 PM
Author Topic: OTS Ringmaster  (Read 1061 times)
Offline Lon Retzloff
OTS Ringmaster
« on: October 21, 2007, 02:00:02 PM »
Does anyone have building instructions for the OTS Ringmaster that they are will to share?  I have the plans, just no instructions.  I'm new at this and want to make sure I'm doing it right.
Thanks, Lon
Offline taildragger-j3
  • Me over 1/2 century ago with my Ringmaster Jr.
Re: OTS Ringmaster
« Reply #1 on: October 21, 2007, 02:50:59 PM »
Do you have the RSM Ringmaster? I just finished one, and I don't think that Eric has a separate "instruction sheet" in his kit. There are some general instructions on the plans, but that's all I found. Maybe one of the other guys has some different info.
David Strawn
Aggieland, TX
AMA - 10212 (original!)
Re: OTS Ringmaster
« Reply #2 on: October 21, 2007, 03:08:16 PM »
RSM has building instructions on their website in .pdf format...not for the Ringmaster specifically, but for several models that should be similar enough to help. I think this is a pretty good idea. A lot of us wouldn't bother to read instructions anyway, but it also makes it easier to make updates and correct errors. OTOH, not everybody is online, but everybody probably knows somebody who is online, or can go to the local library and get the pdf's printed out there.  http://www.rsmdistribution.com/index-2.htm   H^^ Steve
Offline Ken Deboy
    • Silk and Dope
Re: OTS Ringmaster
« Reply #3 on: October 21, 2007, 10:13:32 PM »
Lon,
There are a couple of Ringmaster fanatics that post pretty regularly here so maybe one of them will jump in. If not, you might find some useful information at http://www.brotherhoodofthering.info a Ringmaster only site with lots of good info on Ringmasters.
cheers,
There is a fine line between "hobby" and "mental illness"
