Rising "horizontals".
Doing a cloverleaf with horizontals that rise truly offends me both as a pilot and a judge. This is unfortunate, because know that I do it all the time. The picture illustrates what I mean, just for the exit from the first loop -- but usually, if you do this on the first loop, even if you see it you're doomed to repeat it coming out of the third. The picture looks extreme, and it is -- but I've seen clovers that look like that in competition.
I should mention here that this is a problem that
everyone does, at least from time to time, and to some degree. The difference is that Paul Walker or Dave Fitzgerald may rise a few inches on a bad day, while some of the truly bad examples of this will have a line that rises at 20 or 30 degrees. As a judge and spectator I very rarely see a falling line here (and I don't see straight lines nearly as often as I'd like).
Most of the time, the immediate cause of the rising line is that the pilot gets to the end of the first loop, and realizes that they don't feel at all comfortable with the amount of room they have to do the second 3/4 loop. Starting a loop at the top is always scary, and starting one low is scarier yet. So, they come out of that first loop in a climb. I suspect that for people who only rise a little bit that there's something about the geometry of the loop, or the way we visualize the "cross" that we have to fly to, that makes us come out a bit late, and thus rising.
By the time that you're at the end of that first loop and starting to get anxious about your altitude,
it is too late. This leads to the
biggest error that I see in the cloverleaf, and it's one that nearly everyone does -- they start the thing way too low. I'm not sure how often it's deliberately too low, from misjudging how little difference there is between 45 degrees and 42 degrees, and how often it is too low because it's hard to gauge 45 degrees at all. But watching people fly, I see clovers routinely being entered as low as 35 degrees or so off of the ground, and sometimes lower -- do that, and you'll mess up the whole maneuver.
I think that most people remember that they're supposed to enter the clover somewhat lower than the 45 degree line, and vastly over-do. I'm also pretty sure that most people aren't actually certain where 45 degrees is, and that this amplifies the problem.
If you're flying on 60 foot lines, flying at 42 degrees puts your plane about 2 1/2 feet lower in altitude than flying at 45 degrees.
That is all. Unless you're really good, you can't gauge your altitude that well when you're flying at 45 degrees, much less fly exactly 30 inches lower.A second, possibly less important reason, is that people (me too, alas) tend to do their top loops too small. Small loops are fast, and imprecise, and because the airplane is really being taxed by doing a loop at altitude, unpredictable. Add to that any fear of being too low, and you tend to come out of the loop late, and rising.
For good intermediate pilots (who've gotten past the worst of the "Scrambled" clovers) up through Advanced (and, sadly, into Expert), here's the story that I see:
- You start the maneuver "lower than 45", because that's what the rule book says -- only you're way low
- You do a loop that's probably too small, and certainly not too big. At the end of it you realize just how close to the ground you are, and you exit a bit late, and rising. (I can't speak for everyone, but I know that I've been at that decision point and thinking "oh s*** the ground is awfully close!" -- and came out rising.
- You probably come into the third loop rattled, or at this point you're just making the thing symmetrical. You do the SAME THING at the bottom of this loop (sometimes people will just get one or the other side rising -- usually, though, they're symmetrical about it)
- You finish, and get a lower score than you could
My advice, then, is that unless you're good enough to get into the top 20 at the nats,
completely forget about 42 degrees. Just establish a line at your best guess of 45 degrees, and stick to it. I can't emphasize this enough -- try to put your horizontal line at exactly the same altitude as the intersections of your vertical eights, and the tops of your loops (these are all the same altitude, yes?). Even if you
can gauge 45 degrees accurately, doing an otherwise perfect clover starting at 45 degrees is just going to make the whole thing a tiny bit bigger, which is going to make it that much slower, that much smoother, and that much more in control. Anything you lose in the judges noticing that it's a bit small is going to be entirely swept away by what you gain in accuracy and smoothness.
As part of this, learn to gauge 45 degrees. In one of his columns, Allen Brickhaus showed a gizmo that would give you a 45 degree sight line. You'll feel really stupid spinning around in the center of your control line circle with it, looking up at 45 degrees -- but you'll also learn how do judge where 45 degrees really is, and thus be able to hit it consistently. Get the gauge, experiment with it, and you'll know why I think you shouldn't worry about the difference between 45 and 42 degrees!
Finally, re-read the bit in Brett's post about the hourglass. You want the tops of your clovers to kiss the same "wingover" line that the hourglass rides along. If you're not getting back that far, then your upper loops are too small, and you're likely setting yourself up for poor horizontals (and possibly bad intersections).
