Thanks for the comments guys.
The plane has a Geo Bolt wing, 26% flat Stab/Ele. My own style Fuse, similar to many others out there.
Traditional constuction, maple beam motor mounts, lost foam wing. The stab is sheeted foam using pro set epoxy and a vacuum bag. I made a male mold of styrofoam for the cowl and then covered it in 2oz glass with pro set epoxy then hollowed out the foam. I recommend this method it is comparable in weight to wood but has none of the fill required that wood has. Plus it wont soak up any oil.
I hope to get it painted here pretty soon. Heading to English color today. I am so affraid of the cost of the paint I need.
I will post more as I go along.
