  • June 22, 2025, 09:18:47 AM
Author Topic: Attack of the killer Ringmaster Giro  (Read 3867 times)
Offline Mike Griffin
« on: October 01, 2016, 04:12:04 PM »
The maiden flight did not go as expected.
Re: Attack of the killer Ringmaster Giro
« Reply #1 on: October 01, 2016, 04:31:10 PM »
Geez, it did the same thing, three flights in a row!  LL~
I'm wondering if the rotor rotation direction was the problem?   ??? Steve
« Reply #2 on: October 01, 2016, 04:56:36 PM »
Fixable?  At least it took to the air -- it looked like it would have provided good line tension once the rotor caught.
Offline Joey Mathison 9806
« Reply #3 on: October 01, 2016, 05:05:30 PM »
mad cow #^
200 mph man ama#9806 joey mathison
Online Motorman
« Reply #4 on: October 01, 2016, 05:10:11 PM »
Pilot didn't give it any pull on take off.
« Reply #5 on: October 01, 2016, 05:37:00 PM »
Tim it is fixable....didn't hurt it to bad.
Offline Michael Boucher
« Reply #6 on: October 01, 2016, 05:40:53 PM »
Should you spin the rotor a little before take off as well?  ???
AMA 59633
« Reply #7 on: October 01, 2016, 06:12:54 PM »
Michael to answer your question...I don't know.  The Otto the Giro kit I did did not require you to do that but with this one...I have no idea.
« Reply #8 on: October 01, 2016, 06:24:15 PM »
I sure didn't see any bits come off when it hit, but I didn't want to assume.
It looked like it rolled in rather than yawing in -- could it need an outboard winglet with some tip weight?  Or maybe point the wheels to the outside of the circle?
If you thought you'd copied every pertinent bit of Otto The Gyro and launched with confidence -- you have my sympathy.  It seems that my worst new-design disasters happen when I'm most confident at launch.
Offline Allan Perret
  • Proverbs
« Reply #9 on: October 01, 2016, 06:59:19 PM »
Post crash, I looked it over.  Thinking he had the LO to far fwd causing it to yaw left soon as it lifted off.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #10 on: October 01, 2016, 07:03:33 PM »
Was that Timmy flying it holding onto the handel (sic)? He didn't display much in the way of foot speed to attempt a save. Was it the Ring Giro's 1st flight? Bad Tim, BAD!   LL~ Steve
PS: Ok, so who was that on the handle?
« Reply #11 on: October 01, 2016, 07:10:05 PM »
Steve the man who was flying it is Ed Shearer.   Ed has been flying lots and lots of years.  He likes the unusual and has built many successful flying machines that are really unique designs.  I am sure he will correct whatever the problem was and get it in the air again soon.
« Reply #12 on: October 01, 2016, 07:15:57 PM »
Well, I'm glad that Ed didn't get whacked by the Killer Ring-Giro. If he can't make it behave, could he send it to Tim?  S?P Steve
Online Kim Doherty
« Reply #13 on: October 01, 2016, 07:19:08 PM »
Mike,
Make sure the wheels track out of the circle. Also have it launched pointing out a bit more. I have flown a box stock plans built "Otto" and it had no particular vices. See this link from Stuka Stunt:
 http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=113710
Kim
« Reply #14 on: October 01, 2016, 07:57:39 PM »
Steve I am totally lost here....who is Tim?
Offline Douglas Ames
« Reply #15 on: October 01, 2016, 10:12:34 PM »
GYRO with a Y...They don't fly without the rotor spinning.
Are the leadouts angled back? Is the rudder cocked to the right?
The rotor just generates lift, you still need line tension.
AMA 656546
« Reply #16 on: October 02, 2016, 11:44:38 AM »
I suspect, based on this and other threads, that Steve has decided that I need an Internet stalker.  While he seems to think that I have a singularly strong ability to crash airplanes, he doesn't realize that it's just a combination of ineptitude and persistence that turns the trick.
Offline peabody
« Reply #17 on: October 02, 2016, 12:11:36 PM »
The intrepid Young Daniel had many successful flights with Ted's gyro....Ted even had a lot.
They always spun the rotor before release and had a wire contraption that the lines passed through that kept them at about mid fuselage and also were a little behind the rotor hub....
When Danny decided to loop the thing, it got ugly.....the blade(s?) hit the lines and it pretty much hog tied the time....Palko can probably quiz Dan or Ted about it....
« Reply #18 on: October 03, 2016, 06:42:55 AM »
Peabody:
Let's suggest to Young Daniel that the time is right for a dyna-jet powered gyro.  Whoa!!
Scott   ;D
Offline peabody
« Reply #19 on: October 03, 2016, 01:50:55 PM »
I'm in!
Offline Dane Martin
  • heli pilot BHOR
« Reply #20 on: October 03, 2016, 01:56:17 PM »
mad cow #^
Hey, that's a real concern. I've had that many times.....  ;D
« Reply #21 on: October 03, 2016, 05:38:17 PM »
Okay Rich - I'll start a new topic requesting that people reply with their "atta-boy" if they want to see Young Daniel build a dyna-jet gyro.   ~^
We can then ask Palko to show the results to Dan.  How can he resist?   VD~
Agree?  I'll post something up and you can add your verbal incentives to it to get the ball rolling.
Scott
« Reply #22 on: October 04, 2016, 05:56:08 PM »
We are thinking you need the Inboard Rotor going FORWARD , unless it flys backwards .
As the air outsides going backwards the outer rotor gets no lift , unless its the inner rotor .
 :## ;D
Perhaps dual contra rotateing roters are required for aerobatics .  #^
