  • July 16, 2025, 01:28:03 AM
Author Topic: Improvised Stand  (Read 1435 times)
Offline Brian Massey
    • California Car Clubs
Improvised Stand
« on: March 09, 2011, 02:34:37 PM »
I got a screwy idea to hold my new plane solidly and try to get the stab and rudder on straight. It seems to work pretty well, and was quick and easy to set up and take down.
As you can see in the pics, it's just two screw clamps and a level. I leveled the fuse fore and aft before clamping (gently), then leveled and blocked the stab. When the glue was set, I did the same with the rudder.
I know many others have ideas to do something that could help us all, anyone want to share? I know I'm always eager to steal a good idea.
Brian
AMA 55421
Madera, CA
Offline W.D. Roland
Re: Improvised Stand
« Reply #1 on: March 09, 2011, 04:53:07 PM »
That Brian is a neat idea! y1
possibly add a triangle shaped piece of ply or other to the stationary part of clamp to keep level side to side?
Might help with wing alignment and be more stable.
Oh
Idea stolen LL~
David
David Roland
51336
« Reply #2 on: March 09, 2011, 08:40:21 PM »
Larry Renger used the same sort of level thang stuck to a stick (fake prop) to adjust his engine thrustline for up/down thrust. I thought that was a good idea. A few days later, I was in my nearby machine shop supply store (Swift Tool) and noticed they had an otherwise identical level gizmo with the Starrett brand on it. I think it was $13, but you should be able to buy them for 99 cents at the "Stupid Prices" store or Dollah Store. Probably all from the same factory in PRC.  :'(  Steve
« Reply #3 on: March 11, 2011, 07:58:34 AM »
Clamp the profile fuselage in a WorkMate.  Use 90 degree triangle to see if verticle with surface.  Set stab/elevator in place and block accordingly.  Works for getting wings level to fuse also.
« Reply #4 on: March 11, 2011, 08:00:22 AM »
Great ideas!  Alignment is critical to a good flying model. y1
Big Bear
« Reply #5 on: March 11, 2011, 09:45:20 AM »
Well Duh! I have a workmate and never thought of that. I did use a 90 degree triangle to help set the wing.
Brian
AMA 55421
Madera, CA
Offline Damian_Sheehy
« Reply #6 on: March 12, 2011, 07:41:54 AM »
You don't even need a workmate.
"Oh sweetheart, I'll help you clear the table after dinner this evening . . ."
Use a straight edge to make sure the two leaves are flat and if not place a shim under one to adjust.
Works like a charm, . . . . . mw~
