  • June 18, 2025, 10:48:02 AM
Author Topic: Threaded Coupler  (Read 3737 times)
Mike Griffin
Threaded Coupler
« on: March 10, 2013, 02:07:43 PM »
If you want to join two threaded 4-40 rods, would a coupling nut work OK or is there a better fastener for this?
« Last Edit: March 10, 2013, 02:24:36 PM by Mike Griffin »
Re: Threaded Coupler
« Reply #1 on: March 10, 2013, 02:25:48 PM »
Hi Mike,
Bill Byles (IIRC ??? ) used to make a coupler that sounds similar to what you are asking for.
If not, just have Jim Lee make what you want!  ;D  y1
BIG Bear
RNMM/AMM
Mike Griffin
« Reply #2 on: March 10, 2013, 02:33:20 PM »
Thank you Bill.. I had not thought of Jim...
Offline Bootlegger
« Reply #3 on: March 11, 2013, 05:33:06 AM »
 Mike, I ave one of the coupler's that Bill Byles makes, send me your mailing address and I'll send it to you.
 In actuality it is a "turnbuckle".
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Joseph Lijoi
« Reply #4 on: March 11, 2013, 06:48:15 AM »
Du Bro and Hangar 9 make 4/40 turnbuckles too.  They ahve two male rods though.
« Reply #5 on: March 11, 2013, 01:06:57 PM »
Don't turnbuckles have one left-hand thread and one right-hand thread?  Looks like Mike wants to joint two rods both of which have right-hand threads.  That's legal now in Washington, by the way.
« Reply #6 on: March 11, 2013, 03:19:13 PM »
Thats correct, one left hand thread and one right hand thread.  Turnbuckles.  They have flats in the middle and the DuBro ones you can buy with wrench.  Threaded male rods on both ends.
The Hangar 9 ones are Titanium.  I guess I thought Mike was looking for a turnbuckle.  Sorry.
Dubro does make a rod coupler that has a female thread and a male thread.  Here is a coupling nut:
http://www.fastenal.com/web/products/detail.ex?sku=0172544
Offline Jim Oliver
« Reply #7 on: March 11, 2013, 03:21:27 PM »
Be careful with the threaded couplers and rods; I have had two of the H9 titanium parts break during normal CLPA use.
Jim
Jim Oliver
AMA 18475
« Reply #8 on: March 11, 2013, 03:22:26 PM »
That went over my head.  After writing the last post I get it.
Mike Griffin
« Reply #9 on: March 11, 2013, 04:15:44 PM »
Thank you all for helping figure out what I wanted.  That was a good one Howard...I think it is legal here in Louisiana too along with.... never mind
Offline Steve Riebe
« Reply #10 on: March 11, 2013, 04:28:08 PM »
McMaster Carr also has them in 4-40 size
http://www.mcmaster.com/#threaded-rod-coupling-nuts/=lu4wr9
Mike Griffin
« Reply #11 on: March 11, 2013, 04:41:06 PM »
What I am looking for is a coupling nut (female both ends) with a Right hand thread at one end and a Left hand thread at the other in a size 4-40.  You could put a rod with right hand threads in each end and tighten both at the same time
« Reply #12 on: March 11, 2013, 05:02:21 PM »
That's not how I remember threads working! You can't screw a RH threaded rod end into a LH threaded nut.
I'm wondering what you're trying to accomplish? It sounds like you just need a longer CF pushrod tube? If you want to adjust your pushrod length, a turnbuckle sort of fitting is required (see Bill Byles), tho I'd rather just turn the rod end and bolt it back onto the elevator horn. A turnbuckle has a RH male and a RH female, as well as a LH male and a LH female thread.  n~ Steve
Mike Griffin
« Reply #13 on: March 11, 2013, 05:45:35 PM »
Steve it was something I was trying to do on a take apart profile with no flaps.  I wanted to be able to disconnect the pushrod at the trailing edge of the wing so once you removed the wing you would not have a long pushrod waving around.  There is probably a better way to do it but I am just blank on how.  Thanks for trying to help.
« Reply #14 on: March 11, 2013, 06:34:03 PM »
Have George Cleveland show you how F2D pushrods work.
Mike Griffin
« Reply #15 on: March 11, 2013, 06:35:55 PM »
Thank you Howard.  Who is George Cleveland and how can I reach him?
« Reply #16 on: March 11, 2013, 06:47:21 PM »
Ahhhh....yes, that helps. A coupler such as from McMaster-Carr would do the job just fine, with one half Locktited, CA'd, or epoxied permanently onto either pushrod. No LH threads needed! If you go to any hardware store, you'll find coupler nuts and "Redi-Rod" (aka "All Thread"), that will give you the idea of what you're getting into. It would be much slicker to have an internal threaded insert in the end of one pushrod or the other. I'd for sure check at Central Hobby in Montana and see if they have the parts already.
Trying to think of another way to do it...I guess you could put a false flap horn ("Idler Arm") at the TE and unhook from that?  H^^ Steve
« Reply #17 on: March 11, 2013, 06:54:29 PM »
George lives in Kenner.  Any local CL flier should know him.
Mike Griffin
« Reply #18 on: March 11, 2013, 06:54:44 PM »
Thanks Steve.  I guess I was just not being clear enough...I think what you suggested will work fine.
Mike Griffin
« Reply #19 on: March 11, 2013, 06:55:34 PM »
If that is Kenner, LA he is just a few miles from me.. Thanks Howard...
Online Lauri Malila
« Reply #20 on: March 12, 2013, 05:01:23 AM »
Isn't that the thing that goes hand-in-hand with legalizing marijuana; according to the bible those who do it, must be stoned. L
