  • July 19, 2025, 01:04:21 AM
Author Topic: New Milling Machine  (Read 2621 times)
Offline Dick Pacini
New Milling Machine
« on: March 28, 2012, 07:16:27 AM »
Finally got my last shop tool.
AMA 62221
Offline Gene O'Keefe
Re: New Milling Machine
« Reply #1 on: March 28, 2012, 07:42:56 AM »
Very nice .... planning on reworking engines ? or ?
Gene O'Keefe
AMA 28386
Offline Dick Pacini
« Reply #2 on: March 28, 2012, 07:53:51 AM »
For those times when I've said "If I only had... .
I owned a manufacturing company for 21 years and have spent most of my working life in the metalworking field.  I have always had machine tools at my disposal.  Now, I have a lathe, drill press, saws and a mill in my basement.
AMA 62221
Offline Clancy Arnold
« Reply #3 on: March 28, 2012, 08:26:55 AM »
Dick
You did not plan ahead.  You should have retained 1 % of the business for a key to the shop and access to all of the machines!!
Clancy
Clancy Arnold
U/Tronics Control
Offline Dick Pacini
« Reply #4 on: March 28, 2012, 08:41:09 AM »
Dick
Clancy
Um...nope.  Complete dismemberment and sale in 2003.  The only thing I kept was my good name, such as it was! LOL
AMA 62221
« Reply #5 on: March 28, 2012, 09:21:07 AM »
Oooooooookay, Dick, gimme your address, I'm green with envy but if I can "drop over" and use it I'll return to natural color! LL~ LL~ LL~
Seriously, I'm happy for ya, looks like a quality tool. y1
« Reply #6 on: March 28, 2012, 09:31:57 AM »
Taig type mills are very cool. I have one and use it all the time. Grizzly, Micromark, Harbor Freight and others sell this mill (under various names). The trick with them is the tooling and making sure you adequately brace the vertical column. In stock form, the column is not all that stable and tramming the the head can be a real pain. But there are aftermarket parts that allows the column to be reinforced and stabilized and it turns this into a very decent mill.
Check out http://www.littlemachineshop.com. They have a ton of tooling, parts and aftermarket goodies for this mill. They even have stuff to turn it into a CNC mill.
Offline Dick Pacini
« Reply #7 on: March 28, 2012, 09:54:08 AM »
Randy, that is where I bought this mill from.  It is a new model that has a solid column.  To my knowledge, LMS is the only supplier of this solid column mill, but it is made in the same Chinese factory as the other brands.  They are all similar.  I also bought the tooling package with a heavy vise, parallels, collets, end mills, edge finder and a clamp set.
AMA 62221
Offline Allan Perret
  • Proverbs
« Reply #8 on: March 28, 2012, 10:40:27 AM »
How much does something like that cost ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #9 on: March 28, 2012, 10:48:21 AM »
When I bought mine they were all the same and it was just a matter of finding the best price. I ended up tracking down a Homer truck sale and got it for $300.00, had to pay sales tax but no shipping.
Does it still have the big bolt that lets you angle the column? The Column on mine is hollow, what did they do, make it out of a solid piece?
Offline Dick Pacini
« Reply #10 on: March 28, 2012, 04:01:37 PM »
The column is hollow but is not adjustable.  The big problem with mills that have a tilting head is that they are not as rigid.  Not necessarily a biggy as long as you take moderate cuts.  If you need an angular cut with a solid column mill, you can use a sine vise.
AMA 62221
Offline Dick Pacini
« Reply #11 on: March 28, 2012, 04:05:02 PM »
http://littlemachineshop.com/products/product_view.php?ProductID=3960&category=1387807683
Figure another 250-300 for decent tooling and freight will run 150-200.
AMA 62221
« Reply #12 on: March 28, 2012, 10:45:13 PM »
dick,
Glad to hear that. I bought a kit by them to stabilize the head. They are good guys.
Offline Dick Pacini
« Reply #13 on: March 28, 2012, 11:15:17 PM »
This is my lathe:
AMA 62221
Offline Bob Reeves
« Reply #14 on: March 29, 2012, 04:38:14 AM »
Thanks, was wondering what the difference might be. Spent quite a bit of time on mine when I first got it making sure everything was square and tight. Never really found a need to tilt the head and have avoided even trying for fear it would be a PTA to get it back square with the table.
I sure use the heck out of it, among the normal usage hard to beat for drilling accurate holes.
