  • July 21, 2025, 06:35:30 AM
Author Topic: If you've built a Reinhardt ISW...  (Read 1547 times)
Offline Terry Caron
« on: December 27, 2015, 11:13:47 PM »
What does (did) it weigh less engine?
Thanks.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Online C.T. Schaefer
Re: If you've built a Reinhardt ISW...
« Reply #1 on: December 28, 2015, 07:57:35 AM »
Hi, I hope this will be helpful. I just got off the phone with LS. Red built many of his planes in Larry's basement, so, at least, we are pretty close to an original source. His recollection is that the ISW weighed 22-23 oz with motor (Fox .35) and tank. Another factoid is that, when Red and Larry were at the Plymouth International together, Red was having tank issues and swapped the tin tank for a Jim Walker pressure system. The first flight with it crapped out early. On the second flight which won the meet, the plane quit just as Red completed the pattern! There may be some original printed material out there but this should be helpful to you.   Tom
Offline Terry Caron
« Reply #2 on: December 28, 2015, 08:11:09 AM »
Thanks for the info and the memories, Tom.
Terry
AMA 249824
NRA Life Member
« Reply #3 on: December 28, 2015, 10:09:13 AM »
That weight sounds right.  Will have to reweight mine I built from the Walter Umland kit.  Also it does like to fly a little fast.
Offline Terry Caron
« Reply #4 on: December 28, 2015, 01:03:15 PM »
So ~18 oz less engine, same(ish) as an All American?
Terry
AMA 249824
NRA Life Member
« Reply #5 on: December 29, 2015, 08:52:54 AM »
But flies a lot better.
Offline Gerald Arana
« Reply #6 on: December 29, 2015, 09:49:15 AM »
What is an "ISW"?
Thank you, Jerry
Offline Terry Caron
« Reply #7 on: December 29, 2015, 09:56:47 AM »
Hi Jerry -
It's "Red" Reinhardt's "International Stunt Winner".
Terry
AMA 249824
NRA Life Member
« Reply #9 on: December 29, 2015, 04:44:42 PM »
Hi Jerry -
Terry
D'oh, I should've figured that out!  LL~ LL~ LL~
Thanks Terry, Jerry
« Reply #10 on: December 30, 2015, 09:20:27 AM »
Don't feel lonesome Jerry as I have brain fade more often it seems.
