  • June 28, 2025, 11:36:59 PM
Author Topic: Two to three blade prop equivalency?  (Read 723 times)
« on: August 02, 2018, 12:32:43 PM »
I did a search but nothing came up, so I'll ask here.
For a 12-4 wood, what would the equivalent be for a 3 blade carbon fiber?  Or even simpler: what is the 3 blade equivalent for a 2 blade prop if the 2 blade is 12 inches in diameter?
I have a couple of Bolly's with split or chipped tips, so I'm thinking I should cut them down and try them on my LA-46.
Scott
Offline jfv
Re: Two to three blade prop equivalency?
« Reply #1 on: August 02, 2018, 12:42:21 PM »
The very "general" rule of thumb is: reduce diameter 1 inch for 3 blade for same pitch as 2 blade.
Jim Vigani
