  • June 22, 2025, 12:10:04 AM
Author Topic: Identify this Motor Please  (Read 1635 times)
Offline badbill
« on: March 19, 2016, 01:36:02 PM »
Anyone know what this bad boy is? If there were markings, they have been ground off. It has phenomenal compression. TIA  #^
Bill Davenport
AMA 28141
Offline De Hill
Re: Identify this Motor Please
« Reply #1 on: March 19, 2016, 02:36:52 PM »
It looks like a 1950 R-B Special - .299 glow engine.
De Hill
« Reply #2 on: March 19, 2016, 02:43:58 PM »
Did they come from the factory milled flat like that, or should we suspect that someone's fuselage was just a bit narrow?
Offline badbill
« Reply #3 on: March 19, 2016, 03:17:47 PM »
Would the shaft out of the back be indicative that it had been made for spark?
Bill Davenport
AMA 28141
Offline rustler
« Reply #4 on: March 19, 2016, 04:57:19 PM »
RB Special - a quality engine in its time. Held the U.S. 29 speed record at one time(?) Gave the McCoys a run for their money.
To me, the top half never seems to match the bottom half. The bottom half looks rather a rough casting. The top half more precise, with some precision engraved writing on it. You can just see what's left of some writing on the bypass. A hint of R or B and the beginning of "special".
Ian Russell.
Offline De Hill
« Reply #5 on: March 19, 2016, 08:01:50 PM »
All of the R-B engines had the crankshaft coming out the back.
the 1946 R-B Special .29 was an ignition engine with the name on the bypass.
The 1947 R-B "C" was an ignition  stroked .29 which had a displacement of .362. No markings on bypass.
The 1950 R-B special was a .299 displacement glow engine. It still had the shaft coming out the back, but the back cover was not drilled for a timer screw and the rear shaft housing was not cut out for points. Name on bypass.
Aren't you sorry you asked?
De Hill
« Reply #6 on: March 19, 2016, 08:12:42 PM »
I have always said and I will say it again, If De doesn't know about, it probably never happened. You always amaze me about this stuff De.
Offline De Hill
« Reply #7 on: March 19, 2016, 08:20:17 PM »
Hi Jim,
I have a book named the American Model Engine Encyclopedia by Tim Dannels.  That's why I sound like I know all this stuff!
De Hill
Offline Garf
    • Hangar Flying
« Reply #8 on: March 19, 2016, 08:26:24 PM »
R-B Special.
Offline badbill
« Reply #9 on: March 20, 2016, 11:07:55 AM »
Thanks for the help ya'll, pretty interesting! If anyone would like this motor, drop me a pm w/ an offer. I'd love to see someone on here get it, instead of going to ebay.
Bill Davenport
AMA 28141
