Hey Gang,
I would like to thank Matt for posting these pictures for me 'cause every time I try the files are always to big.
Apparently some of you are asking for specks on the new bird.
The aerodynamics are all Pattern Master specs in a United Suit. Yes, this resembles the Brodak kit but is the 60 size PM.
The wing area is 770 squares and the moments are 10 1/2 by 18 1/4 and the weight, unfortunately,
The finish is a Hodge podge of a few products. The under coating is Randolph's Nitrate dope which was used as the initial coats on the raw balsa. I then used 00 silk span on the wing, which is built up millennium style and planked with 1/16 inch balsa wood. All other parts are covered in carbon avail, again using nitrate dope to put down. Automotive primer, out of a spray can was used for the filler and the paints were PPG auto for the metallic green (Special Mix Custom color). The red and blue are Certified clear, the white and black are Sig and the Chrome Yellow and purple are also PPG automotive mixed colors.
The top coats of clear are all certified and I used different thinner or what I had around at the time which Randolph's and Certified Butyrate Thinner.
Th power is a PA 75 on a Randy New PA 75 Pipe.
The prop is a Bolly 13 1/2 X 4.5 and the tank is a Randy 7 1/d oz tank made by Brodak. The spinner is also a Randy spinner and the wheel pants and gear are carbon fibre.
The initial flight's have not been taken yet, and I'm planning on trying her out tomorrow for the initial flight's and I'll be using .018 cables made up by Tom Morris. Although the weight calls for .021's, I don't have to use them till I use the ship in competition. and I'll let you know how that work's out when I get around to it. I'm not even sure where to get .021 lines.
I am happy with the way the ship came out, but not so happy about the weight. I was shooting for about 73 ounces. I weighed this on a Postal Scale and possibly it's lighter then it showed on my scale. Who knows ?
I want to thank you all for your positive compliment's. Since my last PatternMaster had Automotive Clear on it and this one is Butyrate dope the wet sanding was a "Bitch". The last ship I had to wet sand was the number 5 United which was also Certified Clear. I hate to wet sand. Oh Well !!
Will let you now how it flies after the weekend.
Thanks and cheers,
Bob "Champione" Lampione
