P'body,
I'm fascinated by your comment re the noise of Mike's electric. I at one time pontificated at great length (big surprise, huh) about the sounds--most of which come from the prop, not the motor--of electrics and how they seemed to amplify maneuver shape distortions particularly in squares and triangles. The tattle tail apparently coming from the loading and unloading of the prop, making a distinctively noticable "varroom" at a higher decibel level.
How would you characterize the difference in sound of Mike's ship and do you (or does he) have any idea what is making the difference???
Ted
Ted,
I agree it is most likely prop noise. I think it has to do with prop stiffness and how tight the corner is. Round maneuvers make little to no noise while squares have a pronounced bight in the corners. I like it.
Of course there could be other factors like prop shape, governor effectiveness etc... but I think they are less likely to be the reason.
The majority of people flying electric use APC-E props which are not very stiff and I would expect they are distorting in the corners reducing the prop noise. I also think a lot of people fly softer corners than I do (or try to do).
Thanks to Rich, Phil and Bob for judging expert.
