  • July 18, 2025, 02:13:37 AM
Author Topic: I think it's time to retire this airplane  (Read 2210 times)
« on: April 14, 2020, 02:22:31 PM »
The FAA will rule that it's pilot error, probably for trusting the ground crew too much.
I was just noodling, testing out an Enya 19.  At the moment this happened I was flying level then the thing darted into the ground from about 12 feet up.  The control system looks intact -- I suspect that the horizontal stab (which I had built up long ago, and which has been repaired a few times) just gave way.
Re: I think it's time to retire this airplane
« Reply #1 on: April 14, 2020, 02:36:45 PM »
Seems done to me.  ;D
« Reply #2 on: April 14, 2020, 03:52:16 PM »
You know you've post-holed it good and proper when you have to really tug at it to get it out of the dirt.
Offline Mike Alimov
« Reply #3 on: April 14, 2020, 04:18:37 PM »
If you left it in the ground and watered it every day, do you think you could harvest baby Flite Streaks in the fall?
« Reply #4 on: April 14, 2020, 04:23:47 PM »
It'd be worth it for the Enya 09's alone -- but how do I know when they're ripe?
Offline Allen Eshleman
« Reply #5 on: April 14, 2020, 06:17:30 PM »
I used a shovel to get an LA 40 on a Banshee out of the ground.  Both engine and plane are still flying - the motor was cleaned up by Motorman and the plane is there, but a terrible flyer.  It won't stay out there on the end of the line.  There is weight in the wing tip, offset of motor and rudder.  I don't know what more to do with it.  Flies on 60 ft. lines.
« Reply #6 on: April 14, 2020, 06:39:34 PM »
Sounds like an engine problem to me!  LL~ Steve
Offline Andre Ming
« Reply #7 on: April 14, 2020, 07:47:18 PM »
I thought "Lawn Darts" were pulled off the market a long time ago?
Andre
Offline pat king
    • PDK LLC
« Reply #8 on: April 14, 2020, 09:13:13 PM »
Always sorry to see one go. That is what we call a "High angle of attack landing". Worst subsoil job I did was to bury my Enya 29 1/2 of a revolution with a 9 X 8 prop. The combat wing was doing about 90 MPH. OOPS.
Think about building the replacement.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #9 on: April 14, 2020, 09:26:15 PM »
You can tell by the look on it's face that it was surprised.  LL~
Dennis Leonhardi
« Reply #10 on: April 14, 2020, 09:36:57 PM »
 LL~ LL~ LL~ LL~ LL~ LL~
Dennis
« Reply #11 on: April 15, 2020, 09:57:28 AM »
Building is happening really slowly around here, and there's a backlog -- but:  here's one.  I'm also thinking of a Ringmaster that actually weighs less than two pounds.
Offline tom brightbill
« Reply #12 on: April 15, 2020, 10:05:27 AM »
Scale up the Aqua Bat and use an Impact wing!
AMA 34849
Offline Serge_Krauss
« Reply #13 on: April 15, 2020, 10:13:25 AM »
If you're tired of it, let it go. Otherwise, why not just fix it gain?
Offline Phil Spillman
« Reply #14 on: April 15, 2020, 10:30:47 AM »
I'd vote to make a new stab and elevator and use it as a break-in engine plane! That way you'd not be wasting fuel at the expense of annoying the neighbors and actually getting use out of the old carcass! many of my old planes still give me satisfaction and fun in fact I just repaired an old Sterling Mustang which I started in 1985! This one was silk covered and I actually found scrap pieces to use to fix the most recent tears!
Phil Spillman
Phil Spillman
Offline John Hammonds
« Reply #15 on: April 15, 2020, 11:33:22 AM »
It's quite impressive when it's electric and all the magic smoke escapes.  y1
The Airframe, Motor and ESC are still giving sterling service (However the Prop and Battery are not).
TTFN
John.
BMFA 165249
Dennis Leonhardi
« Reply #16 on: April 15, 2020, 09:49:26 PM »
"I think it's time to retire this airplane"
Proof again that our logic is often flawed.
The proper question: Is it time for the pilot to retire?
Dennis
Dennis Leonhardi
« Reply #17 on: April 15, 2020, 09:52:30 PM »
So .......  you take a shovel with you when you go flying!?!  Hey, I gotta ask!
Dennis
« Reply #18 on: April 16, 2020, 08:40:09 AM »
Dennis
Never!  Particularly in this case -- on investigation by the proper authorities (me), a decision was made that the pilot (me) was only in error for not giving it a sufficient pre-filght.  The real culprit was the A&P guy (me) who performed an inadequate repair on the severely-damaged horizontal stabilizer, which failed in flight.
Offline Nova Joe
  • Illegitemi non carborundum.
« Reply #19 on: April 17, 2020, 08:24:54 PM »
Add some compost and a bit of nitrogen.
Nova Joe
Nova Joe
AMA 166
« Reply #20 on: April 18, 2020, 06:39:45 PM »
Any C/L model is a good candidate for a rebuild after a mishap.
With one exception...
                    ANY PROFILE
(these are best left in a broken state..however minor)
Offline Steve Scott
« Reply #21 on: April 19, 2020, 06:05:53 PM »
Another reason why I still fly CL.  I never have to walk further than 60 feet to perform 'rites'.   I was flying a high performance RC foamie wing a couple of weeks ago.  After a high speed pass, it shut down and fell from the sky, plowing through several branches before it hit the ground.  I had to slug through ankle-deep mud, corn stubble, briars and spent another 10 minutes trying to locate it (I did).
It's repairable - when I get around to it...
John Gluth
« Reply #22 on: April 19, 2020, 07:39:57 PM »
I vote with Phil! Been given so many foam airplanes requiring repair in the last 12 years. Also re-kitted several balsa CL stunters. Here to say, more successful and happier working balsa. With a little TLC and patience, balsa restoration and finish consistently turns-out nicer. To repair or not to repair? My criteria, how much oil soaked and can that be rectified?
« Reply #23 on: April 20, 2020, 10:48:07 AM »
Yes, rebuild/repair the plane.  Then help other that can't afford this hobby fly it with help/coaching.   A lot of flying time left it I would guess. D>K
« Reply #24 on: April 20, 2020, 01:06:57 PM »
There's not a stick of wood longer than six inches in the leading edge, or about 12" in the TE.  It's not a plane -- it's a collection of repairs.
« Reply #25 on: April 21, 2020, 04:08:20 PM »
Hey Tim.  I would be happy to send you a new leading edge.  Contact me with detailed dimensions, etc.
