  • June 28, 2025, 10:55:32 AM
Author Topic: TAKE APART RINGMASTER  (Read 1993 times)
Offline ericrule
« on: July 24, 2013, 06:49:01 PM »
The venerable OTS Ringmaster has been re-designed so that you can remove the wing, stabilizer, elevator, fin and rudder from the fusleage. This allows you to transport the model in a small car or even to carry it on a commercial airline.  We have even designed the fuselage to accept an electric power package.
Please visit the RSM Distribution page in the Vendors' Cornor for full details
Mike Griffin
Re: TAKE APART RINGMASTER
« Reply #1 on: July 24, 2013, 10:00:14 PM »
Actually the attached picture shows the battery we use on the Take Apart Ringmaster and the battery is best mounted under the outboard side of the wing as shown.  There is a line drawn across the battery showing where the center of gravity is located...hope this helps.
Offline John Cralley
« Reply #2 on: July 25, 2013, 06:37:31 AM »
Here is the mount that I am using. It ends up in a similar position as the one above. It is 1/8" ply and the wing needs to be reinforced during the build.
John Cralley
AMA 52183
Central Illinois
Offline ericrule
« Reply #3 on: July 27, 2013, 01:03:14 PM »
MM;
We are using a 3 cell 3300 mAh battery. If you look at Mikes post you will see how it mounts.
A good trick is to mark the C/G location on the fuelage. Put a matching mark on all of the batteries you plan to use on the model. All you have to do is to make sure that you place the battery and C/G marks together and you will always have the proper C/G (always assuming that you got it right during the flight trimming process) for your next flight. Andy Borgogna taught me that one. It works great!
« Reply #4 on: July 28, 2013, 07:44:36 AM »
You mean us old dogs can learn new tricks!! LL~ LL~ LL~   Don't worry I am still working to get an electric set up.  Can't make up my mind on the Mustang or the Ringmaster.
Mike Griffin
« Reply #5 on: July 28, 2013, 09:05:36 AM »
That is a good way to do it also John.   Thanks for the help on the phone the other day.
Offline ericrule
« Reply #6 on: July 28, 2013, 01:49:39 PM »
Hey Doc:
All I can say if Woof Woof!
Hope to see you at VSC next March. Missed you this year.
Eric
Offline James Mills
« Reply #7 on: July 28, 2013, 02:56:47 PM »
Hey Doc make the decision easy, build both. LL~
James
AMA 491167
