And it's not only about ring but having the whole package right.
The mainstream Jetts, PA's etc. are good because that's the technology they master. But you also must remember that it's the technology made obsolete by MB's with integrated costruction and that's what we are adapting to stunt now. It would be easier to make it without ring. But not better.
I don't know what "MB"s are.
The problem is illustrated abundantly in this thread - you are talking about measuring to microns or rejecting the parts. I don't know what you do in Finland, but I don't carry a precision machine shop to the soybean fields in Indiana. We have people talking about not being able to get parts for STs and K&Bs, and no one being able to make acceptable parts. While there may be some other issues going on here, I know I have worn out exactly 2 ABN/ABC/AAC cylinder/piston assemblies in the last 27 years, both after flights counted in the thousands. And I won one fo the most competitive contests in the world *after it was clearly on its last legs*.
It was a great year if you got through an entire season with a single ST ring and acceptable power, and many times they lasted weeks. Replacement parts wouldn't be necessary if didn't wear out (again, in terms of *microns*) in the first place.
Requiring hyper-precision fits and extreme care that is almost impossible to achieve is not an indication of superiority, it indicates a fragile system with no robustness.
All I know is that I spent endless hours screwing around with engines, rings, brake cylinder hones, in the hot central valley Sun for hours when I had ringed engines. When I got an ABC and later AAC, I stopped having to do that, and forgot about wearout and "what the heck happened to my engine this time" problems that were rampant at the time. I make changes to make it run differently, if you leave it alone, it runs the same.
