  • July 19, 2025, 04:15:59 PM
Author Topic: Composite construction  (Read 2766 times)
Offline Elwyn Aud
    • Inferalandings Photo Page
« on: January 10, 2012, 01:02:22 PM »
I'm trying to get this all straight in my head. What materials would be included when talking about composite construction? Carbon Fiber, plastic, fiber-glass, foam, others? What would non composite include? Wood, metal, various coverings like silkspan, etc.
Re: Composite construction
« Reply #1 on: January 10, 2012, 01:53:17 PM »
Actually, by definition, a balsa silkspan wing is a composite structure, as is a foam core sheeted wing.
however, typically people are refering to composite construction as either molded or vacuum bagged components,,either epoxy and glass, or epoxy and CF
Offline David M Johnson
« Reply #2 on: January 10, 2012, 03:12:03 PM »
What Mark said!
David Johnson
We're havin some fun now!!
« Reply #4 on: January 11, 2012, 09:59:34 PM »
Dang. This thread died way too young. Basically, I'd say that "composite" means the combination of two or more materials into a sammich (sic) to optimize the structure. Such as, for example, "laminated dog crap", or just one layer with an epoxy binder.  LL~ Steve
« Reply #5 on: January 11, 2012, 10:23:02 PM »
Steve, come on now, we all know you just posted so you could quote the "laminated dog crap" line,, sheesh
basically the definition for a composite structure is the combination of two dissimilar materials used to create a matrix which takes advantage of the best of each materials properties,,
or according to Wiki-know-it all,,
composite materials are,,,, engineered or naturally occurring materials made from two or more constituent materials with significantly different physical or chemical properties which remain separate and distinct at the macroscopic or microscopic scale within the finished structure.
oddly enough no mention of laminated dog crap or even multilayered dog crap,, was listed,, there was not even any mention of dog crap in a paper bag on the porch lit on fire,, perhaps you should do your civic duty in your retirement time, and update the wikipedia definition to more accuretly define this?
« Reply #6 on: January 11, 2012, 10:27:42 PM »
Steve O ,,
in case you want to update the listed definition,,( or incase you normal folks should want to look at it yourself) here is a hotlink to the site,,
http://en.wikipedia.org/wiki/Composite_material
It is fairly comprehensive in talking about quite a few different applications. Interesting reading for sure,,
« Reply #7 on: January 11, 2012, 10:32:59 PM »
Mark, you weren't persistent enough.  Just one click away is the page for perhaps the oldest composite material known to man, Wattle and daub: http://en.wikipedia.org/wiki/Wattle_and_daub
Wattle and daub (or wattle-and-daub) is a composite building material used for making walls, in which a woven lattice of wooden strips called wattle is daubed with a sticky material usually made of some combination of wet soil, clay, sand, animal dung and straw.
Online RandySmith
« Reply #8 on: January 11, 2012, 11:05:52 PM »
Now Steve  it seems that to be a real composite..the laminated dog crap would need another substance in the matrix of the composite...maybe with bounty towels...
birch ply....saran wrap....or such.. :-)
« Reply #9 on: January 11, 2012, 11:47:47 PM »
Tim
again well played,, I missed that, however I did see the reference within the host article regarding wattle and daub, however I am not so sure that it qualifies as actual LAMINATED dog crap,, its more a semi homogonious mixture  rather than a strict lamination. As you know, laminations are represented by striations of material, Whereas Wattle and Daub is not a lamination but rather matrix similar to an epoxy and resin matrix,,
« Reply #10 on: January 11, 2012, 11:51:57 PM »
True.  But if you used two layers of wattle, with daub (made, of course, from dog dung), then it would be "laminated dog crap" in the same way that we might talk about "laminated epoxy composite".
« Reply #11 on: January 12, 2012, 08:37:37 AM »
No wonder you guys are not ready to fly yet.   Spring will be here before we know it and I will still be working on a canopy.  Have went thru two bottles already and am going to try a smaller bottle. H^^
Mike Griffin
« Reply #12 on: January 12, 2012, 09:03:59 AM »
Hey Derek !!!  They are using your quote again about the dog crap......better jump in here..... #^
Offline Geoff Goodworth
« Reply #13 on: January 12, 2012, 04:39:10 PM »
May I be permitted to return to Elwyn's question for a moment?
If you apply Mark's definition strictly, applying glass or carbon fibre to the nose of a model is composite construction.
Similarly, I regard Dee Rice's very clever moulded balsa skin wings that were written up in Flying Models a couple of years ago as composite construction as well.
« Reply #14 on: January 12, 2012, 06:16:15 PM »
Geoff, technically, silkspan over balsa with dope is a composite construction method..
« Reply #15 on: January 12, 2012, 07:55:47 PM »
Agree, Mark.  H^^
« Reply #16 on: January 12, 2012, 11:57:46 PM »
Exactly.  H^^
