OK, not literally but I thought that might grab your attention. Eric Rule, owner of RSM Distribution and I have been working on a joint venture to produce something a little different that we both think has a future for Control Line flying.
For the past few weeks we have been working on logistics and pricing to get this program out to you and we just came to an agreement today after I spent about 30 minutes on the phone beating up on him and squeezing out good pricing. I had to do some arm-twisting but I got it out of him. Actually it was not that bad and I was able to compliment him into it.
Most all models that are labeled as RTF (ready to fly) or ARC (Almost ready to cover) are imported into this country from the communist Chinese. I myself had owned a few of these but found that before I could fly them, I had to strip the covering off, change out the control system and use epoxy or CA glue to repair loose joints where they used a hot glue gun. But regardless of the inferior workmanship and materials, they have sold prolifically and there are thousands of these models in the air every day counting both Control Line and RC models.
The concept of a model that is built to the point of just having to install a wing and tail and go fly, has been tremendously successful in the circle of people who either do not want build, do not have the time to build, do not know how to build or do not have a place to build. Or, maybe they have all of that but just rather buy something that requires very little time and labor to put it together and just go fly. In addition you still have to glue in a wing and tail and hope you got the incidence right and they are level.
What we want to do is take that concept (Less the gluing together part) and improve upon it by using all contest balsa, quality components for the control system, and expert building skills to offer you a package you will be proud to own and will have fun flying. Plus they just screw together.
Here is how Eric and have worked out the logistics. He will laser cut the kits, send them to me and I will build them to the point of Ready To Cover (RTC) and then ship them out of New Orleans.
Now here is the great part, the models we have selected to start with, will all feature TAKE APART engineering. In addition, they will be built for either a glow engine or an electric motor. I took two glow Take Apart Ringmasters to the contest in Baton Rouge and sold them both the first day within a few hours and got an order for three more from a hobby shop. I wish I had taken a dozen.
We picked 4 designs we are going to start with and then we will take others into consideration as the program develops.
They are:
The Tutor (not the Tutor 2 that was offered at one time as an RTF)
The Flite Streak
The Magician
The Ringmaster.
With these take apart designs we are offering, once you have covered the wing in your choice of materials, painted the fuselage and installed the power system of your choice, you are ready to go fly. There is NO GLUING INVOLVED in assembling these planes. The wing, stab and rudder simply bolt on using a few 4-40 socket head bolts. After flying all you have to do is take it apart and store it in your closet if you wish. These take up a lot less space than any permanently assembled model. You could carry 20 of these in the backseat of your car if you so desired. I did not take into consideration a smart car.
NOTE: Eric Rule is now engineering the Magician Stab so we can make it a take apart also so it may be a little longer delivery time.
I will be posting the pricing in my section GRIFFIN’S BUILDING SERVICE, in Vendors Corner.
There will be an introductory offer that will run through December 15, 2014, which will be posted in my Vendors Corner section, Griffins Building Service.
One final note, if someone absolutely insists that they want the model shipped with the wing covered, I will do it for an additional fee which I will list with the prices in Vendors Corner. I will NOT do any painting of the model. That will be left up to the customer.
If you have any questions, please contact me and I will do my level best to answer them.
Here is the link that will take you to the pricing...
http://stunthanger.com/smf/index.php/topic,37239.0.htmlThanks from Mike and Eric…
Sorry for posting the picture of the Ringmaster twice.
