So, I built this Fancherized Twister in 2013. I chose to build a Twister, and to leave its wing as designed, because I'd had such good luck with rebuilding my Skyray and my Flight Streak. I know that a D-tube wing would tend to break badly or not at all, while the Skyray (and Twister) style wing tends to burst the covering but do much less damage to the wing.
And I was crashing
All the time in 2013.
So I finished up the Twister, started flying it in competition -- and stopped crashing. Always, I was straightening out that wing, because the downside to that style of construction is that the covering lends the wing torsional strength, and at least with 'coat, the wing tends to creep out of straight, and needs to be periodically gone over with a heat gun and judicious twisting.
So, today, I'm getting ready for the
Shelter in Place Showdown. For some reason the dang thing is going limp on the lines up high, particularly in the overheads -- I shortened the lines to fit the field I can fly in, and it's affected the trim.
So this was going to be my flight to really pin down what's happening overhead. I did the Hourglass, it went
really limp this time, and I managed to recover from the downward leg at what would have been 3" below grade, if only one could fly through dirt.
And -- the wing structure did what it should! I've just got some diagonal tears in the outer wing, and as far as I can tell there's not even a broken glue joint! This sucker's getting patched up with shipping tape and Monocoat and I'm going out there again to finish trimming it out.
And it only took seven years of flying before my decision on how to build it justified itself...
