  • July 14, 2025, 10:51:16 AM
Author Topic: ...I am searchin'  (Read 983 times)
Offline Bootlegger
...I am searchin'
« on: January 11, 2011, 10:05:21 AM »
  :!      For the "O" ring that you fellow's are usin' to put the difuser's over the trumpet shaped R O Jett venturi's.
  I want to keep the :gradeaux" out of the motor...
   Tank's a lot... #^ #^    :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Richard Grogan
Re: ...I am searchin'
« Reply #1 on: January 11, 2011, 10:51:57 AM »
Hey Gil. Not sure about the RO Jet specifically, but Lowes and Home Depot carry a variety of O-rings in various sizes in their plumbing departments. We also use regular nickle plated copper wire twisted tight securing/clamping our pantyhose material stretched over the venturi, as well as cable ty-wraps pulled tightly. Also, auto parts houses sells the green o-rings used for auto AC systems...many sizes to choose from. They hold up pretty well to heat, as auto AC sys can generate some serious heat.
Long Live the CL Crowd!
                  AMA 85745
Online john e. holliday
« Reply #2 on: January 12, 2011, 03:40:34 PM »
Also, any of your local auto parts stores should have small O rings. H^^
