  • July 18, 2025, 06:28:55 PM
Author Topic: PT-19 Tail Wheel Assembly, Thanks Igor  (Read 1212 times)
Offline Larry Fernandez
« on: May 31, 2013, 08:29:05 PM »
Among the many awesome details of Igor Pachenko's plane, was the scale like forked tail wheel unit.
He was kind enough to show me the photo album, of the entire build of his plane. There were several photos of how he fabricated the tail wheel fork.
As soon as I got home, I cut the tail wheel off of my PT-19 and made up one like his.
Check it out
Larry, Buttafucco Stunt Team
Offline Paul Walker
Re: PT-19 Tail Wheel Assembly, Thanks Igor
« Reply #1 on: May 31, 2013, 09:44:41 PM »
OK, I'll bite.  How did he make it?
« Reply #2 on: May 31, 2013, 10:10:12 PM »
Just a block of aluminum, roughly shaped with a band saw. Then final shaped with a file.
The top of the fork has a boss that fits into the aluminum sleeve. The landing gear wire passes through the sleeve and into a hole drilled into the boss at the top of the fork. The whole assembly is then bonded together with J B Weld. I added a couple of rings cut from a brass tube.
His looked better than mine.
Offline Paul Walker
« Reply #3 on: May 31, 2013, 10:54:22 PM »
Let's see a picture of yours.
That's a lot of work for a tail wheel! How much did yours weigh?
« Reply #4 on: May 31, 2013, 11:46:29 PM »
That is a picture of mine.
I didn't think to weigh it before I put in on.
After the cockpit detail, it didn't seem like a lot of work at all.
Online Howard Rush
« Reply #5 on: June 01, 2013, 01:19:41 AM »
My tailwheel strut sophistication is commensurate with my cockpit detail.
« Reply #6 on: June 01, 2013, 02:39:31 AM »
Im friends with Yves Fernadez ,some of the custom made components in his planes just make me feel inferior as a builder.
Some build for function with minimal weight penality
Some take the opportunity to build a tail wheel and construct it as beautful as can be crafted.
Me thinks of a certain Ted Fancher and his cowls that fall into the latter..........
Is it wrong to take pride in your work ?
Offline MarcusCordeiro
« Reply #7 on: June 01, 2013, 09:32:17 PM »
Very cool Larry!!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #8 on: June 02, 2013, 10:21:11 AM »
I follow Yves pictures on FB and his work is incredible. According to Larry, Igor's work is just as nice. I would like to see it in person.
Derek
« Reply #9 on: June 02, 2013, 10:24:05 AM »
BTW, nice work Larry, I love your PT 19
Derek
