  • July 18, 2025, 04:38:23 PM
Author Topic: Conversation from electric to IC  (Read 1010 times)
« on: May 12, 2017, 07:52:03 PM »
I'm thinking of converting an electric profile to IC and canting <sp> the engine so the muffler is on the belly.
Anyone have any suggestions or ideas.
Was thinking about using a RC mount.
Thanks in advance.
Offline Bob Hudak
Re: Conversation from electric to IC
« Reply #1 on: May 13, 2017, 05:30:00 AM »
Paul,
 Most electric profile setups don't have the stiff nose required for fuel setups. Electric motors don't bang around like fuel setups. Hardwood motor mounts might need to be installed and electric profiles are usually built with thinner plywood nose doublers so you might need to add more than a R/C mount to the nose. I once witnessed a 3D R/C electric, that was converted to controline with glow power, tear itself apart in flight at a contest.
            Be safe,Bob
350838
« Reply #2 on: May 13, 2017, 09:41:28 AM »
Hey Bob
Thanks for the feed back. Maybe a little more info. This was a IC profile that I converted over now want to back.  #^
Offline Allan Perret
  • Proverbs
« Reply #3 on: May 13, 2017, 10:00:41 AM »
I think the RC mount is your best option.
Allan Perret
AMA 302406
Slidell, Louisiana
