  • July 03, 2025, 03:09:31 AM
Author Topic: Pleese go to your profile and del Zip  (Read 1714 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: January 15, 2008, 04:24:08 PM »
If everyone would go to your profile and delete your zip code the weather will quit trying to load and speed the forum up for everyone. Even if you are not seeing a slow down it will be faster for you...
Thanks...
Offline Clancy Arnold
Re: Pleese go to your profile and del Zip
« Reply #1 on: January 15, 2008, 05:03:36 PM »
Thanks Bob.
I have had no complaints about the speed of this forum, but deleted my ZIP Code and was surprised at the improvement.
Clancy
Clancy Arnold
U/Tronics Control
Alan Hahn
« Reply #2 on: January 15, 2008, 05:20:58 PM »
As a matter of detail, it has been noted that Firefox loads faster than IE in this situation (the weather link IP missing)---so even it isn't the perfect solution, it will help you individually until Sparky deletes the linkage of the ZIP to the weather site. I have deleted my ZIP, but I am guessing it will be a long time before everyone does---or even everyone in any individual thread gets around to it.
Offline Bill Adair
  • AMA 182626
« Reply #3 on: January 15, 2008, 05:52:47 PM »
Don't forget your airport (ICAO) code, if you used that instead of your zip code.
Offline Bob Reeves
« Reply #4 on: January 15, 2008, 11:59:20 PM »
Bump
Offline RC Storick
Re: Please go to your profile and del Zip
« Reply #5 on: January 16, 2008, 07:44:46 AM »
Hey thanks for tying to help me run this. However this is still under my control. What if I don't want people to remove their zip code. This forum is run on PHP and is hard to manipulate files. So in this case its OK,but next time before giving orders please contact me or moderator.
Offline Ward Van Duzer
« Reply #6 on: January 16, 2008, 08:13:49 AM »
OK, so I'm dumm... What's with "BUMP"?
w.
Offline Bob Reeves
« Reply #7 on: January 16, 2008, 08:52:20 AM »
I did discuss this with you in the open several days ago, at the time you said you would delete the links to citywx.com. Hasn't happened so figured you were tied up and couldn't get to it.. Removing your zip code fixes the problem.. Thought I was doing the forum a favor as I am sure I'm not the only one that gets tired of waiting for threads to load.. Although I'm probably the most verbal.
Offline Bob Reeves
« Reply #8 on: January 16, 2008, 08:55:08 AM »
w.
Any post makes the thread go to the top.. "Bump" bumps it back to the top..
Now please delete your zip code this thread loaded fine except for you...
Offline Dave Nyce
  • Flying
    • Revolution Sensor Company
« Reply #9 on: January 16, 2008, 05:42:25 PM »
Sighted zip, sans same.
Seems faster now.
Dave Nyce   New Bern, NC
AMA: L356
« Reply #10 on: January 17, 2008, 07:33:14 AM »
Have not deleted zip code.  Been timing the posts on how long it takes for them to come up.  What is a couple of seconds unless the plane is on the down side of reverse wingover.  DOC Holliday
Offline Bob Reeves
« Reply #11 on: January 22, 2008, 08:39:35 AM »
Bumped, because I received an email from someone that couldn't find the zip code threads..
