Flying in such limit wind conditions is almost suicidal...it's NOT fun and the price you pay is too high...
Flying in a drained peat marsh , in the wet season , the decelerations way less . They go in 6 inches or so .
Fast Footwork helps no end , but remain ing in the ' center ' is not so easy !
This thing got planted a dozen or two times , MANY ' hits ' including a tree or two.
Started with a 21/35 ST , tried OS 35 , ST 35C , ST 21/40 , ST 21/46 - and the nose fell off .
Magnum FSR 25 OS clone , with a 7.5 mm intake & a leaky spraybar ( useless run sealed ) .
Was Best ! His O ' Head eights very reminiscent of this . When the flexy 10 x 6 lost a 1/4 inch
on a touch'n'go on the concrette resivoir , the suction from the wind ! , it imediately went better ,
Eventually wore the front of the tips round , in the grass .
Fighting and struggling its way round , up the top . Like the sheets against the wind , in a yacht .
Of Course , it's all rather Manly ! (
) They cant get the tractor mower on there for a few months in winter , it'll bog .
Big Suction under a treee or two . Winds predominantly from bottom left corner across & up , about 30 degree . After falling over the ridge , back of there .
Flew over to the right , mainly . Mostly off the screen . LEARNT to GET THE LINES TIGHT , many near misses , so not entirely misses .
Run , Get Em Tight . usually full up or down so the ' yank ' which removes a lot of the inertia / momentum - ROTATES it - amost ish . The 5 ft. turn . !
IF it goes in SQUARE the stress distribution is more even so the wings are less liable to fall off , and the fuse snap . Like if you just stand there
admiring the view, which can lead to the ' blow down ' on outsides getting a STRIKE on the Concrette Picket which , CRICKET PITCH . inverted . Opps .
Has the nice slippery nylon grass topping , but catching the fin on the edge dosnt help . Theres probably still a few dents in the field from it .
Its about a acre of concrete up on top of the world here , so might be termed exposed . Discretion may be the better part of valour here .
the Gieske Nobler went in vertical after a stall , around 1976 . A Combat Wing with a ETA 29 doing a Kamakazi flat out , from 200 ft . Dead Center -
fortunately stopped , as the fuel pickup was upward . And shidded in umarked at out feet . These were learing about hitting your wake eppisodes .
Whole District is enveloped in suburban neurosis & televisioniteus in the promising new age . Not to mention the traffic .
So . Dont try this at Home .
Dont Use your ' best ship ' . used 55 + .018 , match for Bob Gieske's 58 ' to center ! . Live & learn . Dont believe everything you see or anything you hear .
Bigger things benifitted from the practise , so were less likely to strike . The 57 in. Folkerts with a 21/40 with a 9 mm intake & C'Case pressure was pretty good , but needed two tanks of fuel to get the scedule through
which may contravene curerent regulations . The YANGA sound on the 11 x 4 was pretty good . The RPR HP 40 worked good . Way Good . If the Lines are TIGHT it'll TURN , is the theory !
Nothing but Fun . Like a Dodge 440 with a stuck throttle on a wet skid pan doing a precision slalom course . Relaxing might not be appropriate , chilling out isnt being soaked to the skin & frozen wet , either .
When the big 150% peacemaker / flite streak , went in vertical , every rib was in three pieces , split vertical or horizontal . Took a entire tin of pins to reglue it , a few hours work - set on planks . 2 R - 2 L .
tho admitadly wasnt at its best afterward . the Phantom seemed to survive ? it's missadventures well . one was only a line break in calm air a fortnite after the picket whitch eppisode , of its 3 wing broke
in middle episodes . I think it was 12 canopies . 2 dozen ' the earth got in the way . Plus a tree . Imediate ( within Two Days ) re glueification is a necesity .
Hosing out the sand inside after the cricket pitch , the water went through under the wing , aft . Two Days in high heat in the car eventually got it back to its 47 / 50 ounces .
A good few hours scrubbing with petrol got it de gook & lawn clippinged - Which got it near ( Er ) its original form . Ten Gallons of ten minute flights . pretty well past a ' Precision Aerobatic ' machine eventually .
But considered it'd earned its keep . Like Parting with a old friend when it was given the chop . Mostly to worn to salvage . Shoulda past it on to continue its missadventures . A bigger donk woulda got it
back on form . Almost .
perhaps I suppose It'd got a bit mushey .
