Randy Smith's NV Assy. is superior in many ways...but a few $ more. I'll use them exclusively, when the others are adequately broken. That goal is approaching fast.
Curtiss Shipp makes CNC machined aluminum backplates for the OS .25, .40 and .46LA's. He's a member here, and you can contact him by finding him under "profiles" and then email or private message. You can also search the swap meets for FP, Tower .40, or Thunder Tiger GP .40 parts, which will all fit. I think this is a solid improvement in reliability.
While you're at it, get a pack of 3mm x .5 x 8mm, and a pack of 3mm x .5 x 12mm socket head machine screws and replace the stock screws. You'll be glad you did.
I ran my .46 one tank on the ground and flew it. No regrets! The first gallon of fuel was 10-29GMA Powermaster. After that, I changed to 10-22. The 11.5 x 4 APC is the best "baseline" prop, IMO. Others like the 12.25 x 3.75 full, or clipped, so try both. Some sort of carbon prop may well work better, but I haven't found it yet.
