  • August 02, 2025, 03:43:45 PM
Author Topic: How to prevent electric starter cone from chattering and bouncing?  (Read 1795 times)
Offline frank mccune
           Hi All:
            How can I prevent the above from happening?  I have a new starter, cone and spinner that all appear to run well without any excessive runout etc.  Due t this excessive movement, the starter jumps off of the spinner.  What can I do to prevent this from happening?
        Tia,
        Frank McCune
Online Dave Hull
Re: How to prevent electric starter cone from chattering and bouncing?
« Reply #1 on: February 04, 2020, 04:08:48 PM »
Practice.
« Reply #2 on: February 04, 2020, 04:47:05 PM »
         Hi Dave:
         Thank for the reply!
          Practice to do what?  How difficult can this task be ?  Press the cone onto the spinner making sure that the starter is square to the engine.  Press the switch on the starter.   Or have starter running making sure that the starter is square to the engine for a brief period.  What else is involved?
                                                  Suggestions/Comments
                                                  Frank McCune
Offline John Leidle
« Reply #3 on: February 04, 2020, 04:57:01 PM »
    Frank,
  I used to give the trigger small short bursts of spin. The longer I kept it spinning the better chance I had to have it chatter. Also lined it up a straight as I was able.
  John L.
Online Dave Hull
« Reply #4 on: February 04, 2020, 07:36:59 PM »
Frank,
My reply was not meant to be smart-ass. In my experience with a starter, how you hold it, apply it, and time it all reduce the normal bumpy-jumpy chatter that is common. If all of your setup is ideal, then the next thing to do is practice. You'll start to work on being steadier. Straighter. On when and how hard to bump it. And so on.
The only engine/starter combinations that never seem to chatter are sport 1/2As that are totally overpowered by a nice 1/2A-type starter. The ones I have seen/used had soft cones.
On the other hand, starting speed engines with high compression and small spinners is frequently a bumpy experience. It gets better when the crew has some practice. The last couple of speed contests, I was the volunteer "starter guy" if someone wanted help. I got to practice, and learned a few more things.
Perhaps some keys are:
   --Strong, fresh battery
   --Proper size cone that fits the spinner on the plane you are starting right then. Not one that fits most of your other planes.
   --Clean cone with no internal cuts, tears, chunks missing or other unnamed damage
   --A softer cone will usually give better traction, but poor technique will damage it much sooner
   --Proper speed starter for type of engine. Just because a starter will do wonders on a racing 40 or stunt 60 doesn't mean it will do anything good to a 1/2A--except damage. This is more than just cone size
   --Plane must have a suitable spinner. Big enough and tough enough to take the loads. No spinner? No usa da electric finger!
   --Prop must not interfere with the cone. If you press the cone onto the spinner and it can contact the prop--including when the starter is not quite square to the whole deal--then it will never work well. Lumpa-bumpa-bump....
   --If you see a lot of damage to the spinner, whether plastic or metal, then the setup or the technique is bad. Melted spinners are most likely from--
   --The engine needs to be in good running condition. Using a starter to "fix" a messed up engine just leads to more stuff that needs fixing. If you can't just spin the starter and bump the spinner and get it to go, then it needs something else to be better prepared for starting. The determined "if only I could get it going so's I could tweak the carb" attitude leaves burn marks on spinners. And grooves. Which tears up cones, or vice versa. Kind of a chicken or the egg thing.
  --Have someone hold the plane and brace it. The guy with the starter needs to use two hands to hold/guide the starter. This may mean one hand on the starter and one on the nose of the plane to make sure he can control the pressure being applied and get it straight. These are often held up off the ground for better bracing. The FF guys like starters on a fixed stand. Hold your own plane and shove the nose into the spinning starter. Foot pedals are de rigueur
   --Adjust technique to match engine and plane. Sport and stunt engines seem pretty straightforward. Speed engines like to be bumped hard. Turn the prop back against compression and have the helper shove the plane into the starter, which is already running and braced firmly by the starter guy. I found the most awkward situation to be the larger 4-strokes. Never was comfortable turning the prop backwards to find compression. Sure, you can use a stick, but I always worried it would fire and grab/throw the stick on me. So I mostly stay away from 4-strokes. But electric starters are perfect for them. Anyone using a starter on 4-strokes would likely be able to help you.
Perhaps it would help to understand one of the things I think causes the starter cone to be "ejected" from the spinner. Imagine that the axis of the starter is slightly off in angle from the axis of the engine. Push the cone into contact slowly. It will first touch on one side--in one spot--on the spinner. There is a normal force (ie. a force from the rubber onto the spinner that is perpendicular to the surfaces in contact) and a friction force. The friction force is in the plane of the surfaces in contact. The engine comes up on compression and it takes torque to force it to go over. This has to come from the friction between one side of the starter cone, because it is the only place in contact. And the reaction forces back onto the starter that the person holding it will feel will not be centered on the axis of rotation of the starter or the engine.  This means that while your brain, which is in charge of your technique, is expecting to handle an axial load (shoving it onto the spinner) and a centered twisting load (torque applied to the crank) it does not know what to do with an unexpected side load, jumpy force walking the cone back off the spinner and to the side. Now, you say that you are pushing hard enough that the cone is in contact all the way around? Maybe so, but if you are slightly crooked, the force on one side is absolutely larger than the force on the other, and when there isn't quite enough friction to turn the engine over easily, it does the same thing. So having all the parts trued up, clean, and holding the starter/plane absolutely straight and steady solves most of the problems. This is where the softer rubber helps. It deforms more at the loads we can apply and so it evens up the friction around the spinner.
So I'm back to my original comment:  Practice.  You'll see what you can do better with your technique, and you'll tweak the equipment as needed as a result.
The Divot
Disclaimer--I prefer to hand-prop sport, stunt and racing planes. I own one starter I've used mostly on speed planes. If I ran 4-strokes or pipe engines or larger than 40ish RC engines, I'd probably be using a starter for all of those. And, I don't use composite props on anything but the racing and speed planes. Except for the tame stunt engines, I use a glove.
« Last Edit: February 04, 2020, 07:53:48 PM by Dave Hull »
« Reply #5 on: February 04, 2020, 08:50:12 PM »
   I was going to suggest "practice" also. Lots of people have trouble using starters that way. No need to grind on and on with one either. If it doesn't start in the first 1 or 2 seconds, back off. A starter can hold an engine back and keep it from running also. Use quick bursts, and use the softest cones that they make. Part of that chatter in the cheaper, harder cones slipping. If you look at videos or photos of guys starting speed models with electric starters, you usually see them using both hands to keep is steady and under control, so keep that in mind. The chatter is one reason some build the starter into a sturdy, stable box or stand to hold it also.
Offline Al Ferraro
« Reply #6 on: February 04, 2020, 09:55:45 PM »
 The Sullivan 631 cone works the best on spinners around two inches.
Al
 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F392100111268
Offline Peter in Fairfax, VA
« Reply #7 on: February 05, 2020, 05:46:24 AM »
The starter itself may be weak.  While I have no need for an electric starter at this time, as the OS LA 46 starts first flip cold or hot, every time, my favorite starter is this one: https://www.towerhobbies.com/cgi-bin/wti0001p?I=SULP1703
« Reply #8 on: February 05, 2020, 08:06:31 AM »
          Hi to all:
          A big thanks to all who have replied! I will devote more time to learning to properly use an electric starter.  I have several engines to evaluate and a good test stand.
          I would prefer to hand start an engine, but due to health reasons, the electric starter has become my friend. Lol
          I am using a new starter, blue silicone starter cone and a new 14.4volt li po battery.  I also have a collection of about 7-8 other starter cones.
          The plus side of this dilemma is that it keeps me out of the bars.
        Be well,
        Frank
Offline Skip Chernoff
« Reply #9 on: February 05, 2020, 08:38:53 AM »
Make certain that the engine you are trying to start doesn't have a bent crankshaft caused by a previous crash. The shaft doesn't have to be out much to do what you've described........Skip
Online Dave Hull
« Reply #10 on: February 05, 2020, 05:52:12 PM »
Frank,
Got to agree with you.  You're just wasting alcohol if you are drinking it instead of running it thru a motor....
Divot
Offline WR Crane aka MrClean
« Reply #11 on: February 06, 2020, 12:14:30 PM »
Higley Nut.  Doesn't necessarily look good on the front of your PAMPA ride though.
Offline Richard Imhoff
« Reply #12 on: February 06, 2020, 03:46:53 PM »
Switch from a 14.4 battery to a three cell 11.1 and your problem will be gone.
14.4 is to fast when used on a starter and the 11.1 calms down the harsh start reaction and still has more power than you will ever need.
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Offline Frank Imbriaco
« Reply #13 on: February 06, 2020, 05:48:22 PM »
The Graupner  reduction geared starter  is small in size, huge in power. I used one with great success on my YS  four strokes(up to the FZ 140) and two strokes up to an OS 140 RX.(R/C 2 meter pattern). No chattering or  slipping off spinner. Slow, powerful rotation.
Don't know if they're made anymore, but scour the upcoming swap meets and you might find a good used one.
Offline Phil Spillman
« Reply #14 on: February 06, 2020, 06:41:07 PM »
Hello Frank, first set up the engine as you were going to hand start it. Prime flip, flip, back of prop from compression, PRESS STARTER FIRMLY against spinner, APPLT Ignitor, finally squeeze the handle of starter. Remove Ignitor, fly!
When pushing starter into spinner hold firmly to plane at LG or Tank if soundly mounted.
Phil Spillman
ps. It might still chatter! Forget about it!
Phil Spillman
« Reply #15 on: February 19, 2020, 09:02:53 AM »
            Hello All:
             A big thanks to all who replied!
            Just an update on my starter travesty.  I think that I solved my starter problems.  The voltage is too HIGH as Richard suggested.  At 12 volts, the starter works very well.  At 14.4volts, it is a beast!
             The “Beast” has launched a starter cone in my workshop to some hidden space not to be seen again.  The last time that I went flying, it launched a starter cone high enough that after its reentry,  it punched through both sides of the tissue covered wing on my Ringmaster Imperial!
              The starter in question came equipped with 10 Ni cads that were weak despite being charged to 12.2 volts.  That is one of the reasons that I went to the LiPo battery.  If 12.2 volts were good, 14.4 volts has to be better! Lol.  Twelve volts did not want to turn over my .40 Diesel or my ABC .40 engines but I will bet that the “old” NiCads were tired.
               I guess that there is an 11 volt Li Po in my future. Lol
               Frank
« Reply #16 on: March 07, 2020, 09:43:29 AM »
          Hi All:
           Thanks to all who responded.
           Richard I got it correct.  I replaced the 14.8 battery with an 11.1 .?. volt battery and all I well!  Since I have only small engines, do not be surprised to see the battery and starter appear in the classifieds. Lol
        Thanks for all of the replies,
        Frank McCune
Offline Allan Leonard
  • A&P Mech
« Reply #17 on: March 07, 2020, 10:57:06 AM »
" The “Beast” has launched a starter cone in my workshop to some hidden space not to be seen again.  The last time that I went flying, it launched a starter cone high enough that after its reentry,  it punched through both sides of the tissue covered wing on my Ringmaster Imperial!"
I'm sorry Frank but I just had to laugh.
« Reply #18 on: March 07, 2020, 12:05:05 PM »
          Hi Allan:
          Good to see that you have a sense of humor! If one does not find a bit of "fun" inn everyday events, then one is missing a lot of enjoyment in life!  It was my plane and I still had to laugh!
        Have a great day,
        Frank
« Reply #19 on: March 10, 2020, 01:28:54 PM »
1) Are you using a spinner, or doing without? A spinner helps a lot, and a needle nose spinner shape works better than the more common shapes. Sullivan has a variety of cone shapes and materials, and of course, the one for needle nose spinners works better on n.n. spinners. IIRC, the one I use is made from "silicone"...it has a gummier consistency than some others I've used. It may also help to run some sandpaper against the wear surface on the cone bore to "break the glaze" and improve "traction".
2) What brand of starter are  you using? The Sullivan is pretty much the Gold Standard, IMO.
3) Always engage the spinner/starter before you hit the switch.
4) I'm puzzled by the reduced voltage comments. I'm running my 12v Sullivan (it's a very old one bought at a swap meet) on Makita 18v. battery packs. The combination is not light, which may help stabilize the starter and prevent chatter/bounce. Getting rid of the power cord is a wonderful thing, and I love the combination very much. I can't speak to other brands of starters (I have or had a Kavan planetary starter I used previously), but the Sullivan company actually has parts available. I believe Graupner and Kavan were both bought by SIG, and they both pretty much vanished after that.  :( Steve
« Reply #20 on: March 10, 2020, 03:09:15 PM »
       Hi Steve:
       Thanks for the reply.  I am using a Hobbico Heavy Duty starter with the 14v battery and a Sullivan cone.  My 11.v starter is the standard Sullivan starter.   I am also using spinners that appear to fit the starter cone very well.  I also hold the starter straight and in firm contact to the spinner prior to pushing the starter strip.  I sanded the inside of the cone but at 14v, there appears to be just too much torque to handle.  Maybe I should hit the gym.
        I have learned to get nearly one flip starts every time making the starter redundant.  If we get one flip starts on each flight for the day, we get to punch our Man Card for the day. Lol  My newest flying mate has taught many tricks concerning stunt flying in the past two years.  It is great to have an experienced stunt flyer for a reference.  It is slow and expensive to learn from one's mistakes!
        Be well,
        Frank
