I have been looking for my previous posting with this drawing, and it seems to have disappeared. So, I've updated it a little, and I am re-posting it at a slightly large size. The wing shows at 644 sq. inches.
The wing is basically a Legacy wing. and uses a NASA 4 digit airfoil, that averages to about 18% thick, with the flaps installed.
The fuselage starts out with many of the Legacy's numbers ad consists of guide lines that will help you roll your own shapes within the normal numbers variations, thus helping you design a a good performing stunter.
There are several files, and I've attached them as .dwg, and .dxf in the A2000 files. most cad systems will open this older format. I've also plotted them as small Pdf files to allow even those who do not have a cad program to be able to see the files.
The ribs shown on the wing plan, can be used by a laser cutter to cut the ribs for you, or you can hand cut them.
Good luck, and if you have any qesions, feel free to contact me.
