  • July 13, 2025, 10:48:55 PM
Author Topic: Drawings of Full Fuselage Imitation  (Read 756 times)
Offline Mike Griffin
« on: March 16, 2018, 07:01:08 PM »
Eric sent me some drawings today of the side view of the full fuselage for the upcoming Imitation Plus kit.
I am proposing that we add the parts necessary to put a tuned pipe on the normal fuse. This would entail two different cowls plus an “add on” which would be glued to the bottom of the regular fuselage sides. That would turn the model from a standard glow/electric powered fuselage into a tuned pipe fuselage.
This way we can accomodate those who want to install a tuned pipe or non tuned pipe glow engine set up.  Of course you could also use an electric set up if you wish.
I am taking orders for the kits and you can see pricing and details in my Vendors Corner section,  GRIFFIN'S MODEL SERVICE.
Here are the drawings:
Just click on the paper clip attachment below.
NOTE:  Everything you need to build the fuselage for either set up will be in the kit.
« Last Edit: March 16, 2018, 07:20:27 PM by Mike Griffin »
Re: Drawings of Full Fuselage Imitation
« Reply #1 on: March 16, 2018, 07:02:08 PM »
Here is a rotated screen view also.
Offline Allan Perret
  • Proverbs
« Reply #2 on: March 16, 2018, 09:27:19 PM »
Will this one also use the RC mount ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #3 on: March 17, 2018, 04:46:40 AM »
No.  Traditional motor mounts for glow.
