  • July 08, 2025, 06:05:01 PM
Author Topic: How strong is Gorilla glue?  (Read 7053 times)
Offline RC Storick
« on: May 20, 2013, 01:32:30 PM »
I am doing a test while making a beam for my new plane. This glue is lighter than epoxy but is it strong enough?
Offline Steve Fitton
Re: How strong is Gorilla glue?
« Reply #1 on: May 20, 2013, 01:51:36 PM »
The dude in the picture says Gorilla glue is seriously strong.....
« Reply #2 on: May 20, 2013, 01:53:39 PM »
  In my very limited experience it is extremely tough (hard to break) but not overly rigid. It's certainly much more compliant than conventional epoxy. I would suggest it in areas where there is a large surface area that stabilizes itself, and not in areas of high point loading (like splicing spars or attaching formers to fuse sides).
Offline Russell Shaffer
« Reply #3 on: May 20, 2013, 01:58:04 PM »
One thing to watch for is parts creeping.  When the glue foams, doublers can slide all over the place if they aren't secured.  Just weighting them down isn't good enough.  But, yes, it is very strong.
Russell Shaffer
Klamath Falls, Oregon
« Reply #4 on: May 20, 2013, 02:01:11 PM »
I have not tried it personally, but have heard that some people like it for sheeting foam wings.
Offline ray copeland
« Reply #5 on: May 20, 2013, 02:09:35 PM »
I use it for repairs, and yes it does foam and creep but it is strong. I do try to dampen the parts a little. I also use it for installing blind nuts and threaded brass nuts.
« Reply #6 on: May 20, 2013, 02:14:24 PM »
Bob, I love my gorilla glue. Started using it on my Saito 72 powered ships when I had epoxy failures. Needed something stronger.
Rick_Huff
« Reply #7 on: May 20, 2013, 02:25:19 PM »
Gorilla glue is very strong, but it's not good at gap filling.  You need to have good, tight fitting joints to get strong bonds.
Rick
Offline Richard Koehler
« Reply #8 on: May 20, 2013, 09:41:03 PM »
I've not tried gorilla glue, instead I like Elmer's Ultimate.  This is the strongest glue I have ever seen, and once dry it can be sanded.  The catch is parts have to securely clamped together since this stuff cures by picking up moisture and expands.  A nice bonus is that it will even bond oil soaked parts since it uses the free hydroxyl groups in the oil to cure.
Offline peabody
« Reply #9 on: May 21, 2013, 05:17:40 AM »
Phil Cartier has been using it for years (decades?)............he can probably answer all of your questions
Offline Paul Wood
« Reply #10 on: May 21, 2013, 07:17:06 AM »
Robert,
Yes, it is strong, but I have not really found a good use for it in the typical model construction.  I used it when it first came onto the market, but the frustration issues of the expansion characteristics made me go back to the old school methods of gluing.  The best use I found was installing hinges, but the expansion into the barrel of the hinge was a real pain to deal with.  I do use it all the time around the house to repair furniture, flooring ,etc.  It is very strong and good for gap filling, but not for models (for me anyway).
Offline RC Storick
« Reply #11 on: May 21, 2013, 07:26:41 AM »
Well I tried in in Lou of epoxy while laminating my beam and CF sandwich. Seems to have worked well. Good bond and light.
Offline Clancy Arnold
« Reply #12 on: May 22, 2013, 07:27:41 AM »
Robert
I used Gorilla Glue to build my CL Scale Taube.  The only thing is that I used their nonfoaming version, APC # 052427620002.  Go to their web site to learn about all of the versions of Gorilla Glue, www.gorillatough.com.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #13 on: May 22, 2013, 12:32:01 PM »
Robert
Clancy
Ahhhh now I'm interested!!!!
« Reply #14 on: May 22, 2013, 02:17:15 PM »
By the way, I also use their Gorilla tape which is the best tape I have ever use. Too many uses to mention.
Offline George
  • Love people, Use things.
« Reply #15 on: May 22, 2013, 03:17:05 PM »
Would a gorilla lie?   ;D  H^^
George
George Bain
AMA 23454
« Reply #16 on: May 22, 2013, 03:37:13 PM »
Was told years ago a  glue is only as strong as the wood it adheres to.   I used Gorilla glue per the instructions on the Primary Force kit.   That fuselage is one of the stiffest I've ever had.  Also the glue will find every little pin hole or worm hole in the balsa.   I believe that is why it is so strong as it gets into the grain of the wood.
« Reply #17 on: May 22, 2013, 05:08:28 PM »
That's exactly what it does!!
Offline Steven Kientz
« Reply #18 on: May 22, 2013, 05:34:50 PM »
  Ireread an article on the best wood glues in the Sept. 2004  issue#157 of WOOD magazine last nite. Their top 3 were Elmer Probond Interior,Gorilla glue and Titebond extend wood glue. Gorilla didn't do very well other than edge grain to edge grain. If you have edge to end grain joints the elmers probond interior, Loctite professional wood worx and titebond molding and trim were the best. iknow this is an olsd article but i'm sure most of the results still hold true.
Steve Kientz
AMA 855912
