When I bought the ARF I had no idea that I wouldn't like the way it flew. Put over 50 flights on it trying to trim it to my preference. The covering started to peel and I saw fuel soaking on the fuselage. That was the decision point to rebuild. By the way, depending on how you count, this is my 5th time building an Oriental, one from a Brodak kit, one a rebuild (even more work than this one since the wing was in three pieces), one from scratch with a foam wing, one ARF and then this one. I could have scratch built a new wing in the time frame it took to rebuild this one.
The Magnum .28 XL has been used on two other planes so far...an ARF Nobler and another Oriental (42 oz.). I modified the engine. It is easily one of my favorite engines and runs very consistently. Prop is a APC 10 x 4. Launch RPM is 11,300 in what sounds like a 4 cycle, although I doubt that very much and when it "breaks" the rpm goes to 12,000. It will pull an APC 10.5 x 4.5, but the airplane is to fast. I live in the suburbs out side of Denver (mile high city) and even on 90 + degree days it pulls with plenty of authority. Most of the members in our club (Rocky Mountain Aeromodelers) express amazement at just how powerfully and well it runs. Not as much power as its bigger brother (Magnum .36 XL) but for my personal tastes, a sweeter engine run.
Here are a couple more photos of my Orientals. The blue/pink one has a foam wing, monokote on the wing, rustoleum everything else. Currently needs fuse repainted after making repairs. Red one is first attempt at an all monokote job. Wing rebuilt after being broken in three separate pieces. Needs another rebuild...wing again in three pieces after cable broke and it looped its way into the ground. This was the one the Magnum .28 was on.
Chris
