Hi Warren,
Here is an accurate method you may want to try.
All you need is the weight of the engine that was used on the plans that made the CG come out as shown on the plans (or where you want it, and or where others have found it to be correct). Or at least the weight of the average engine used in this very popular plane. My guess is that a Brodak .40 or the OS .46 would do fine for your sample purposes. Here is the link with the weight you need for the OS .46:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPUE3&P=7Now measure the distance from the CG on the plans and the center of the above engine as shown on the plans, (or where you or others have put it in the past to balance the model on the CG). Multiply this measurement times the weight of the above engine. You will now have the moment arm.
Now, divide the above moment arm # by the weight of your 4stroke engine. The answer is the distance between the CG and where your new 4 stroke engine (center line) will be mounted.
This will get you very close to where you need to be. The smaller fuel tank that will be used by your 4 stroke will make a small difference, and if you want you can compute it's impact using the above procedure.
This is the method I used to locate all my ECL equipment when it replaced a 2 stroke wet engine. It worked perfectly. I am a little AR so I made a SS for several planes, very easy to do.
Remember to use the weight of your mufflers, if any. If you want better accuracy you may want to weigh the props, the 4 stroke prop will be larger, and maybe the spinner if it will be different. Just include these weights as part of their respective engines, but use the actual (weight CG) center line of these combined items when measuring.
I think you will really like this 4 stroke in your plane. I love mine! They are almost as good, and almost as quiet as my ECL planes. :-)
