General control line discussion => Open Forum => Topic started by: Phil Coopy on May 08, 2007, 09:38:26 PM
Title: How much time...
Post by: Phil Coopy on May 08, 2007, 09:38:26 PM
Sounds like a dumb question, but I am graduating from beginner stunt to the full sequence, so about how much runtime should I expect will be required?
Phil
Title: Re: How much time...
Post by: Trostle on May 08, 2007, 10:07:59 PM
From engine start to completion of the full AMA pattern, assuming typical lap times of 5 seconds plus or minus a couple of tenths, no extended ground time before release of the model and no extra laps beyond the required minimum two laps between maneuvers, the pattern is completed in something around 6 minutes.  Faster lap times will result in pattern completion in less than 6 minutes.
There could be a case argued to adopt the 7 minute limit of the FAI rules.  It would save time to run the contest and require less time for the judges to work.
Keith Trostle
Post by: Greg L Bahrman on May 08, 2007, 11:47:15 PM
You have to get it all done in 8 minutes. Hand signal the judge and he starts his stop watch. Start your motor do the pattern and land. when the plane stops moving the judge will stop his watch. Anything under 8 minutes is good, over eight minutes and you lose your pattern points etc. and basically your out of the competition.
Post by: Phil Coopy on May 09, 2007, 05:35:22 AM
Thanks guys,  my concern is tank size.  Right now I'm running out after 5.5 minutes/tank.
Phil
Post by: Bill Little on May 09, 2007, 06:27:45 AM
I like to time mine for no more than 6:30.  If you're running 5:30, you need another 30-45-60 seconds.
If you're getting over 7 minutes "RUN" time, you *might* be close when it comes to contest time.  We tend to take longer getting the engine started and such in the beginning.  Maybe not, but it sems to be normal with nerves and apprehension...........
Post by: Bill Hodges on May 09, 2007, 06:47:08 AM
Phil:
I time the engine run on all my flights and I shoot for about 6:30 run time when flying the full pattern.  That gives me about 6:55 total time and that is comfortable for me.
Bill Hodges
50 days till retirement!!!!  n~
Post by: rob biddle on May 09, 2007, 06:53:27 AM
  Hi Phil,
I wasn't too concerned about the total run time when I started learning the full pattern. Just more concerned about having the plane in a "retrieveable" position when I knew the engine was about to quit. ;D
A stop watch can be a mans best friend when learning the pattern.
The main focus for me was to learn all of the manouvres one at a time until I could fly the whole pattern.
I put all of the stunts together in sequence with all of the level flight laps every flight right up until I learnt the clover, by which stage I could fly the pattern and the proper order of things was then second nature to me.
I just need to get good at it!
After I could complete the pattern in sequence I concentrated on the total elapsed time of the engine run.
When I am sport flying with the local blokes we try to load as much fuel on board as possible. It gives you more air time over the course of the day as lots of coffee drinking and general BS get in the road of the serious business of flying!
 Cheers, Rob.
Post by: Phil Coopy on May 09, 2007, 07:38:15 AM
Thanks guys,  I'm gonna need a bigger tank.
Phil
Post by: Jim Morris on May 09, 2007, 07:39:59 AM
Hi Phil, for a general rule of thumb, I like about 10 laps after the clover leaf. This will allow a little room for different weather conditions. Always start out with too much fuel and fine tune it after you get your engine set up the way you want it. This will save the loss of fuel at a very bad time.
Post by: Bill Little on May 09, 2007, 07:40:32 AM
Phil
Hi Phil,
I forgot to ask, what size tank do you have, and what engine?
;D
Post by: Ward Van Duzer on May 09, 2007, 10:16:35 AM
This assumes (theres that word again!) the full PAMPA pattern. OTS takes less of course!  H^^
Ward-O
Post by: Bill Little on May 09, 2007, 10:22:43 AM
Ward-O
Yes, Ward, Phil stated that,  "I am graduating from beginner stunt to the full sequence".
I take that to mean the full "PAMPA" pattern. ;D
