  • June 29, 2025, 08:07:13 AM
Author Topic: How many would like to order PA 65 Rear Ex? rear EX ONLY  (Read 6395 times)
« on: December 09, 2017, 07:33:43 PM »
Since the replies on  the other thread  indicate  people would want  Rear exhaust, I am  asking  about these  on this thread
Thank you for your  input
Offline Larry Fruits
Re: How many would like to order PA 65 Rear Ex? rear EX ONLY
« Reply #1 on: December 09, 2017, 07:41:18 PM »
Hi Randy,
 At least 2 for me, maybe 3.
 Would these be in the original size 65 case, or the 75 case?
Thanks;
 Larry Fruits
« Reply #2 on: December 09, 2017, 07:59:31 PM »
Certainly at least 1.  I currently have three!
Offline BYU
« Reply #3 on: December 09, 2017, 08:43:57 PM »
2 please
Offline Tim Redelman
« Reply #4 on: December 09, 2017, 10:58:05 PM »
Put me down for 2 !
Tim
Offline Jim Oliver
« Reply #5 on: December 10, 2017, 09:44:01 AM »
Two for me.
Jim
Jim Oliver
AMA 18475
« Reply #6 on: December 10, 2017, 04:47:25 PM »
Would the case be the same size as the 61 RE?
Projected price?
Thanks!
« Reply #7 on: December 10, 2017, 05:11:10 PM »
Will these be AAC
I think the PA65 has always been AAC in the past.  All three of mine, obtained over a period of 15 years or so, are AAC.
« Reply #8 on: December 10, 2017, 05:15:21 PM »
Projected price?
Thanks!
I think He said before that they would be Merlin cases which are different and a little larger in some places.
Better in most respects!
« Reply #9 on: December 10, 2017, 06:22:00 PM »
Projected price?
Thanks!
Hi Scott
If I do a run of  RE and  SE  then yes  they would use the  Old  original cases,  If I do only  65s  It maybe possible  that the  NEW  Merlin  case  would be used,  NOT decided yet,  as  I need  to see  what the  demand for these  are
Offline tom_weedman
« Reply #10 on: December 11, 2017, 05:19:55 AM »
One for me
Tom Weedman
AMA 63672
Offline Bill Ambrose
  • Bill Ambrose AMA 880
  • Definitely NOT a "new" pilot
« Reply #11 on: December 11, 2017, 05:49:23 AM »
Randy,
I would like one 65 RE, possibly two.
Bill Ambrose
AMA 880
Online Don Jenkins
« Reply #12 on: December 11, 2017, 09:01:26 AM »
I would take one PA 65 RE.
Don Jenkins
Offline Terry Bentley
« Reply #13 on: December 12, 2017, 05:41:36 AM »
I think I would like one.
« Reply #14 on: December 12, 2017, 03:43:12 PM »
I want one, Randy.
Chris...
Offline Rick Bollinger
  • AMA 931589
« Reply #15 on: December 12, 2017, 07:29:53 PM »
Two for me Randy.
Rick Bollinger
AMA 931589
« Reply #16 on: December 12, 2017, 09:50:13 PM »
Will these be AAC
YES   ALL  PAs  are  AAC
« Reply #17 on: December 12, 2017, 10:23:13 PM »
The 65SE is one of the most devastating stunt engines I have ever seen!! Without question, one of THEE all time greats.
« Reply #18 on: December 16, 2017, 04:01:00 PM »
Randy Do have an idea of the price ? and what would the price be with a header and pipe?
Online Ken Bird
« Reply #19 on: December 16, 2017, 04:48:53 PM »
Randy,
I will take one.
Offline Skip Chernoff
« Reply #20 on: December 18, 2017, 04:56:24 PM »
Randy I'm not familiar with this engine,but have a few questions as I may want one for my new SV11. Is this a long stroke engine? What is the weight of the engine less muffler/pipe? How does the mounting pattern compare to a ST 60? What are the fuel requirements? Lastly what type of prop size and pitch does it like? Thanks Much.
« Reply #21 on: December 18, 2017, 07:18:22 PM »
Hi Terry   I will  post that when  I am able to tell  which  engine  I  will  make, and get all  sorted
« Reply #22 on: December 18, 2017, 07:22:43 PM »
Hi Skip
The PA line of engines have been around all over the  world  since  the mid 1990s   ,  Many 100s of people have used them, the are  about  11.3 ounces  exhaust depends on versions, mount size  can be  varied but is  close to the  OS  SF 46   VF  46, they run a  wide  13 inch 2 blade or  12 to 13,5 inch  3  blade  4 to 4.7  pitch
I will  give you more info  as soon as  it is decided  if they will be made  and  what  will be made
« Reply #23 on: December 19, 2017, 09:44:46 AM »
Thanks Randy ,I look forward to see the post what the pricing.
Offline Gerald Schamp
« Reply #24 on: December 19, 2017, 11:24:42 AM »
Put me down for at least one, maybe two.
Offline Sean McEntee
« Reply #25 on: December 19, 2017, 08:28:44 PM »
2 por favor
Offline Rob Duckering
« Reply #26 on: December 19, 2017, 11:03:10 PM »
One please
Duck
Offline Mike Ferguson
« Reply #27 on: December 20, 2017, 07:31:46 AM »
Please put me down for one as well.
Offline Michael Schmitt
« Reply #28 on: December 20, 2017, 12:25:35 PM »
I'm good for 2 Pa-65's Randy
Offline ALEX ORTIZ
« Reply #29 on: January 09, 2018, 06:02:09 PM »
I would like 1 please.
ALEX ORTIZ
Alex Ortiz
« Reply #30 on: January 25, 2018, 12:50:36 PM »
Hi Randy , what is the difference between the Merlin case and the old case?
Offline Alex Becerril
« Reply #31 on: January 26, 2018, 11:37:20 AM »
One for me
« Reply #32 on: January 26, 2018, 02:45:00 PM »
Hi Terry
The rear Merlin case  was a NEW design we did  just for the Control line stunt engines, the Older  Rear  case  was  from an unmachined casting I used from henry Nelson's Q 40 rear ex motor, machined  to my specs  with different exhaust and  bore sizes
This is one  size  of the  Merlin case
« Reply #33 on: January 27, 2018, 11:30:42 AM »
Thank you Randy, I like what your doing with your engines.
Offline Jared Hays
« Reply #34 on: January 29, 2018, 07:36:01 PM »
I may have to try one just to say I did,  how much are they Randy?
« Reply #35 on: January 30, 2018, 08:00:57 AM »
I would highly recommend it. Best IC motor ever made.
Derek
Offline Larry Fernandez
« Reply #36 on: January 30, 2018, 11:53:20 AM »
Hi Terry
Is that a right angle spray bar I see in the picture?
Larry, Buttafucco Stunt Team
« Reply #37 on: January 30, 2018, 02:31:18 PM »
Hi Jared   I have not  got the orders  yet, and  It may change  so I will announce  price  when I decide  to run them
« Reply #38 on: January 30, 2018, 02:33:02 PM »
Hi Larry   There are  3 there,
1- Standard  NVA
1-L  NVA  used for  rear mount needle
1- same side  NVA, the fuel pickup and needle are on the same side, these are  great for side ex  to get away from the muffler,  also  they are  hi flow
Offline Russ Main
« Reply #39 on: January 31, 2018, 02:20:40 PM »
My brother and I are in for 2 and probably 3.
Thx
Offline Jared Hays
« Reply #40 on: February 03, 2018, 11:36:23 AM »
I would be interested in one 65SE if they bolt up to ST 60 mounts Randy.
Offline Mark Weiss
« Reply #41 on: February 05, 2018, 07:04:18 PM »
Hey Coach, I will take a .65 RE
Thanks Randy
Mark
« Reply #42 on: July 21, 2018, 09:47:35 AM »
Will there be a new production run of RE 65s coming anytime soon? Or would it be more prudent to start looking around for a used one instead?
« Last Edit: July 22, 2018, 06:50:21 PM by RandySmith »
Offline Jared Hays
« Reply #43 on: July 22, 2018, 06:07:21 PM »
I want one if this thread is still viable PA 65 RE
« Reply #44 on: July 22, 2018, 06:49:47 PM »
Hi Mike
I wanted to run a  65  RE  and  SE  run, that turns out  not to be a go,  So I will look at  running more  75s  and  65s RE only, the  65 will be  a  Merlin 65  based on the  75 case, This will make for an even better on more stable 65,  This will be necessary because of the  expense of the  Foundry that does castings.  I will get back to this project  soon,  Right now  I am redoing and putting  the  SV  laser cut kits back in stock, and making  NEW  airplanes into laser cut kits, plus I am developing new products  and  concentrating  on getting  Cf PIPES  back  in stock,  I have stock on most of them now, except for the  75 pipes  I am filling the back order quickly now  and  look to get them back in stock in the  coming  weeks
If I started  the  new engine run  NOW  it would be  at least 6 months before I got parts in, then time  to build  all the engines, so  the answer to your question is if you need one  quick, you would  try to find a person that had them for sale
« Reply #45 on: July 23, 2018, 10:53:53 AM »
Hi Mike
Thanks Randy! Appreciate the update.
