  • July 20, 2025, 08:06:24 PM
Author Topic: How many 3/32 stringers in a Vector Kit?  (Read 1106 times)
Online Paul Taylor
« on: April 02, 2011, 11:46:33 AM »
Calling Vector Tech Support !!!
The plans say to glue 3/32 stringers on the top and bottom of one side of the fuse. OK so I look in the kit and find 3 stringers. One long one that fits the top edge of the fuse and two that will fit on both bottoms of both sides. Oh so I am missing one? Well I just happen to have a backup Vector kit and I go in the kit to rob Peter to pay Paul. Same number and sizes of stringers. And as I said before I only see one step that talks about putting stringers on one side, but I have not seen anything about the other side getting stringers.
Sorry for all the newbie questions but this is my first build of a full fuse.  HB~>
Re: How many 3/32 stringers in a Vector Kit?
« Reply #1 on: April 03, 2011, 07:06:04 PM »
nope - you aint missing one - the top one only goes from the doubler to the LE of the stab - then you need to cut it and install the last little bit from the stab to the back of the fuse.
the bottom one is the same - is butts up against the rear of the doubler - but goes right through.......another "Wynn" tip here tho - mark where the tailwheel mount goes, and leave the stringer out there also - as fitting the tail wheel plate in with the stringers in place is a PITA
Online Paul Taylor
« Reply #2 on: April 03, 2011, 07:30:23 PM »
Thanks Wynn!!!!
Great tip on the tail wheel !!!!
Can you remember any more little "Wynn Tips"???
« Reply #3 on: April 03, 2011, 09:16:17 PM »
Thanks Wynn!!!!
tons oh them.....what do you want to know?
I might give you a phone call one day when you are free..
Online Paul Taylor
« Reply #4 on: April 03, 2011, 09:39:47 PM »
Hey Wynn,
Sent you a PM with my number. Give me a holler some time.
Nite. Z@@ZZZ
