  • June 22, 2025, 10:47:31 PM
Author Topic: It's About Time - Tom Dixon  (Read 2652 times)
Offline Jim Catevenis
« on: December 03, 2019, 08:16:17 AM »
                                                          “It’s About Time!”
     I used to fly with 3-time USA F2B team member, Bob Baron. Until his death in 1999, after a 20-year battle with Leukemia.  Bob won the NATS in 1996 with his version of “Big Jim” Greenaway’s Patternmaster.  Greenaway is gone too, as are many other prominent designers and flyers.  Bob Baron was always acutely aware his time on earth would be limited. (He died at the age of 54.)
     After his NATS win, he came home saying, though he had won, the full-size 740 square inch Patternmaster “isn’t good enough-It’s too hard to hold onto in heavy wind” due to it’s wing area and 70-ounce weight.  Bob, when he was not 100% healthy, simply could not fly it up to his own potential.
     The original “Time Machine” was thus created, as a 10% linear reduction of the Patternmaster, resulting in a 640 square inch model, with proportions of the Greenaway design.
     Jim Greenaway had designed the Patternmaster sometime around 1979 (according to flyers who knew Jim well) thus making it Nostalgia and Super 70’s legal.  Jim had wanted a plane “his size”-he was huge! - to use a Merco .61 for power.  He incorporated some really important design ideas, including very thick airfoil for lift, and constant speed, (Al Rabe concept) and simple, “almost no blocks” construction for quick building and light weight (Les McDonald’s Stilettos).  Wing and stab/elevator were foam and Jim produced cores for these.  Plans were drawn by Mike Rogers, another prominent member of the Flushing Meadows (N.Y.) stunt group.
     I published the down-sized “Time Machine” in Flying Models” in 1998.  Bob Baron flew my original for hundreds of flights.  As a result, he built his own version, which he called “Spartan:”, (after his lifestyle!) and used it to be top qualifier in his circle at the 1998 NATS (Double Star .60 Lite power.)  Unfortunately, the wing folded during a warm-up flight on top-20 day.  (I had argued for plywood-stub spars in the cored wing.  He felt it wasn’t needed…to save weight. The #1 Time Machine did not have a fully cored wing.)
     Bob never really got to show the plane’s potential as in late 1998 he became ill again, and died in September of 1999, twenty years ago… though it seems like 5 minutes ago to me.
     Which brings me back to the concept of “time”.  It seems like many of us pursue this hobby/sport as if we will be here, and healthy, forever.  That is simply not true.  Having lost a number of friends like Bob Baron, I am keenly aware of this.  As a result, everything I do in stunt has a time element.  I am always after “quick, easy, and functional enough to be competitive.”  The next plane I build could be my last one, and the same is true for you, too.  Also, making the hobby “time efficient” allows more time for other important things – family, friends, church, and so on.
     With that in mind, I want to re-emphasize my product line with it’s “time” theme.  I offer a range of kits, including contest oriented profile models, and full fuselage models, including all size versions of the “Patternmaster”, from the full-size Greenaway version down to 1/2A size.  All kits have pre-sheeted cored wings, contest balsa parts and landing gear hardware.  You supply your preferred wheels, control system, and power system.  I can even offer these with wing and tail surfaces “pre-finished” in Ultracote or light fiberglass/nitrate dope.
     I can do this because I have come up with production methods that are very time efficient for me.  As a result, you too can benefit from this time-focused concept.  Call, or write for details, designs offered, and levels of pre-fabrication.
     One other thing, I have flown a number of designs since Time Machine #1 in 1996.  I have also flown other people’s Time Machine versions in several sizes.  I am convinced there is something special about Greenaway’s layout, regardless of size.  I have never found anything as easy to fly well.  That’s why, as I write this, I am building a full-size Patternmaster for Stalker .76 power.
Tom Dixon
November 25, 2019
Controline Sales, LLC
315 Santa Anita Avenue
Woodstock, GA 301289
Phone/FAX (770) 592-3279
Offline John Leidle
Re: It's About Time - Tom Dixon
« Reply #1 on: December 03, 2019, 09:24:36 AM »
    Well written Tom,
   If you are able to get the new plane ready for Muncie this year there will be at least 2 big bore Stalkers there. I finishing a plane now with an .81 up front.
        Thanks for your support of the hobby,   John L.
Online Peter in Fairfax, VA
« Reply #2 on: December 03, 2019, 06:16:20 PM »
Side or rear exhaust?  Pipe?
« Reply #3 on: December 03, 2019, 09:28:16 PM »
Thought Id better put a picture on ,
 in case theres any recently inhabited planets that may not be familiar with the Pattern Master / Time Machine .
Anda linkor two .
https://stunthanger.com/smf/nostalgia-30/big-jim's-n30-designs-patternmsater/
https://stunthanger.com/smf/as-time-goes-bye/bob-baron-photos/msg148995/#msg148995
You can obviously butcher , Er RESTYLE them to your hearts content . As did a certain Urtnowski .
And they fly well at horrendously rediculous weights , If the lines'l take it . 84 Oz & .018 Solids .
Easy to fly accurate . And theres not really an issue regarding lack of line tension .
Online Steve Berry
« Reply #4 on: December 04, 2019, 07:26:24 AM »
Can you make one of those Time Machines all electric-fied? Once I finish the 2 birds I'm building, I'm wanting to go totally electric (to eliminate the mess & save my hearing), and that sounds like a good way to go.
Edit: Actually, I would need one that's 35-40 size, since I only have a small car available for transport. Either that, or a take-apart version.
Offline Jim Svitko
« Reply #5 on: December 04, 2019, 08:28:00 AM »
I would say that you could use electric on just about anything.  I see no reason why you could not do it to a Time Machine 40.  I bet someone has already done it.
I have only used glow engines but someone can probably give you some advice on how to go about using electric on any size Time Machine.
As far as I know there are three sizes of the Time Machine series: 40, 50, and 60.  This indicates glow engine size so you can use that as a guide to determine what electric components you will need.  If you must have a 35-40 size plane due to transport limitations, you will not be disappointed in the 40.
Offline Ron Varnas
« Reply #6 on: December 04, 2019, 08:18:50 PM »
The real McCoy  ;D
RJV Melb. Australia
« Reply #7 on: December 05, 2019, 07:34:47 AM »
As a current inhabitant of the profile planet, this thread is interesting, as it shows full fuselage planes.  I did just acquire a Stiletto w/ ST .46 and am waiting for warmer flying weather.
Still interested in some details about the powerplant of the Time Machine, and Patternmaster. e.g. Side vs. rear exhaust, any muffler/pipe, tank size, prop, that sort of thing.
Peter
Offline Charles Carter
  • Flying Control Line Stunt
« Reply #8 on: December 05, 2019, 11:28:13 AM »
The real McCoy  ;D
After seeing the patternmaster with a clear canopy and pilot it is better looking to me.  All the other pictures of PM's without a clear canopy and pilot never was exciting me.
Charles Carter
Offline Jim Svitko
« Reply #9 on: December 05, 2019, 02:20:19 PM »
This is a Time Machine 60.  That is, the wing and all the numbers are that of a Time Machine 60.  Super Tigre 51 for power.
I never liked the looks of the original Time Machine/Patternmaster.  Maybe it is just me but something about it just did not agree with me.  So, when I build one, I change the fuselage.
« Reply #10 on: December 05, 2019, 06:50:19 PM »
Was told of a Profile patternmaster , DS 60 , just the other day . And why not .
If anyones talking to Tom Dixon , They could ask him how many Merco 61 wrist Pins he has .
Was a PING . click . as it hit the tin wall . But finding it would be an extravaganza .
« Reply #11 on: December 05, 2019, 06:55:27 PM »
Heres a real very Pattern Master NOSE .( at 89 % note wing area )  Bin gotat with Twink & a pencil aft .
Generally , you just take a chainsaw to the underside , to set it up for a rear exhaust .
« Reply #12 on: December 05, 2019, 09:38:58 PM »
 :-[  I was expecting to read that Tom had at least bought a typewriter, if not gotten email. Too much to ask for, I guess.   :-[ Steve
Online Sina Goudarzi
« Reply #13 on: December 13, 2019, 04:16:36 AM »
Drawing based on original paint scheme and typography of Big Jim's PM.
Sina
