  • June 27, 2025, 10:10:28 AM
Author Topic: Got a new 'lectric motor, charger and two batteries...yes, I did!  (Read 1348 times)
That's a shocker, I know. Got it all assembled and ready to go flying today, but the weather is too good for that.  ;)  Here's the link to the stuff I bought. Cool thing is, it'll work with all sorts and sizes of props, AND it came with a 1/2" chuck! The only problem I see is that it'll only work with right hand rotation props. <grin> y1  Steve
http://www.afineredgemfg.com/
http://www.cpooutlets.com/makita-xfd01-lxt-18v-3-0-ah-cordless-lithium-ion-1-2-in--driver-drill-kit/mktnxfd01,default,pd.html&antisku=antiskuB&cgid=drills&start=68
« Last Edit: March 12, 2016, 03:52:53 PM by Steve Helmick »
Offline JoeJust
Re: Got a new 'lectric motor, charger and two batteries...yes, I did!
« Reply #1 on: March 12, 2016, 02:11:01 PM »
I thought at first you were going to tell us you bought some new stuff for the Bass boat.
Joe
I only enter contests so somebody else is not always in last place
Online Tim Wescott
« Reply #2 on: March 12, 2016, 02:11:40 PM »
No reverse switch?
Online Gerald Arana
« Reply #3 on: March 12, 2016, 02:31:33 PM »
Steve,
Switch any two motor wires and it'll go the utter direction  ;D But I think you knew that already. y1
Good luck, Jerry
« Reply #4 on: March 12, 2016, 03:48:33 PM »
Yeah, switch the wires...sure...ain't happening. Mike Potter brought this up...adding a DPST switch, but alas, no room for that. His solution is to have two starters, one RH and one LH. It would be possible to add a spacer in there, just for that DPST switch, but Mike already has extra starters and Makita batteries, so his solution works for him. And best of all, I don't have to worry about it, because all my IC's only run the proper direction. FWIW, we both had to make some mods to get the assembly done. I sent an email to FinerEdgeMfg, detailing our problems and suggested fixes. This is a damned fine concept, plus I didn't have a cordless drill, so it made sense for me to buy the whole Makita kit. Don't tell the wife!  n1  Steve
« Reply #5 on: March 15, 2016, 03:53:37 PM »
FYI, got a reply from Kevin Madsen, the owner at "A Finer Edge Mfg.".  He said that the reason I had problems was because my Sullivan starter is an antique version. Also, I should have removed the blade contacts to solder them. Um, that wasn't in the instructions....Kevin sent me a link to a set of photos that would have helped a lot with assembly. He also said he likes the Hobbico starter's switch design a lot better, and it seems to be more reliable. If you order one of these adapters, make sure you get the assembly pictures!  y1 Steve
