  • July 03, 2025, 04:13:24 AM
Author Topic: Which Synthetic do you use  (Read 1320 times)
« on: July 30, 2021, 09:29:20 PM »
"Intentionally left Blank"
« Last Edit: August 15, 2021, 10:03:36 PM by Motorman »
Offline Matt Colan
Re: Which Synthetic do you use
« Reply #1 on: July 30, 2021, 09:31:07 PM »
I mix Klotz Super techniplate in my fuel that I use for PA’s. I forget the exact part number but it’s mixed 80% synthetic and 20% castor. I mix to 20% oil content and then various amounts of nitro (5, 7.5, 10, 12.5 and 15)
Edit: I’ve also mixed some Klotz KL-198 light techniplate in the past as well, but use the Super Techniplate exclusively now
Offline Reptoid
« Reply #2 on: July 31, 2021, 01:57:35 PM »
I usually use Klotz KL205 Original Techniplate and it's been great but can't find it in gallons and it's about $65. I would hate to buy quarts at $24 a bottle. I've also used FHS 62R with great results but this stuff is getting pricey.
If you mix your own fuel, what do you use for synthetic oil?
Motorman 8)
Mostly Klotz Original Technoplate but sometimes Motul Micro 2T (pricey). You can get the Klotz KL-205 here for best price I've found
https://www.summitracing.com/parts/klz-kl-205
Buy two gallons and shipping is free.
       Don
       AMA # 3882
Offline Istvan Travnik
« Reply #3 on: July 31, 2021, 02:57:45 PM »
I use MOTUL Micro 2T, in 20%, for 10-15 years.
I cancelled Castor fully from my life. Hopefully, forever... :)
Istvan
Online Howard Rush
« Reply #4 on: July 31, 2021, 03:00:24 PM »
Ucon LB625
Offline Mike Hazel
« Reply #5 on: July 31, 2021, 06:29:27 PM »
Offline Reptoid
« Reply #6 on: August 01, 2021, 08:41:12 AM »
Motul is a blend, Istvan, it has castor in it🙃. L
No it doesn't.
Motul "Micro 2T" is 100% synthetic. They make many blends of two stroke oil. Micro 2T is Not motorcycle oil. It is is made for model engines.
https://www.motul.com/us/en/products/micro-2t
       Don
       AMA # 3882
