  • July 01, 2025, 10:51:47 PM
Author Topic: Hinge Gap Taping  (Read 2157 times)
Hinge Gap Taping
« on: July 10, 2013, 04:26:51 PM »
OK Folks, bare with me. Can some one either carefully describe gap taping or point me to a thread on it?
Re: Hinge Gap Taping
« Reply #1 on: July 10, 2013, 04:33:30 PM »
  Try this one:
http://stunthanger.com/smf/index.php?topic=11355.msg99465#msg99465
Offline Chris Wilson
« Reply #2 on: July 10, 2013, 05:54:29 PM »
Its winter time here in Oz so I ain't going 'bare' with anyone!
MAAA AUS 73427
Offline Paul Walker
« Reply #3 on: July 10, 2013, 06:48:35 PM »
Winter in Oz......
Is that when it drops to 25C???
Brrrrrrrrrrrrr....
Offline Dallas Hanna
« Reply #4 on: July 10, 2013, 06:56:58 PM »
Winter in Oz......
Brrrrrrrrrrrrr....
Was around zero C here at Richmond a few days ago Paul!  Too cold to play in the shed early mornings!!
HH
« Reply #5 on: July 10, 2013, 09:12:04 PM »
  Try this one:
Thanks Brett, but I'm still a little confused, I realize the tape fold has to occur at the hinge center line. What about the hinge itself? The tape will contact both leaves of the hinge and since the remainder of the tape pushed down to the centerline doesn't is bunch over the hinges and drag in the eyes? You don't trim out around the hinge eyes do you?
Online Tim Wescott
« Reply #6 on: July 10, 2013, 09:21:24 PM »
Randy, what I do is get the tape as deep into the gap as I can, which is usually just touching the hinges.  So the tape doesn't fold at one point, but gently bends over 1/8" or so.
That leaves a hinge that's still slack enough for the surface to flop around of its own weight, which is my personal standard for "good enough".  When you get it to that point, the tape is not going to be the worst contributor to stiffness or friction once the whole control system is hooked up.
« Reply #7 on: July 10, 2013, 09:48:06 PM »
Well, I guess I'm just going to experiment and see what I can see. Thanks Tim.
Offline Paul Walker
« Reply #8 on: July 10, 2013, 10:03:04 PM »
HH
How do all the Croc's stay alive at 0 C???
« Reply #9 on: July 10, 2013, 10:03:30 PM »
   I used to use separate pieces that go between the hinges. Then Paul Walker told me he found a big difference when he went over the hinges, so I use a single continuous piece. I put oil on the hinge barrels and stick it right down to the hinge, makes little difference in the drag or binding. It didn't make a huge change when I first changed but it doesn't hurt anything so I kept doing it. Although I did crash the airplane on the very first flight with it that way. It wasn't due to hinge sealing, the remnants of Hurricane Dennis was a significant factor, that and my basic clumsiness.
   Note also that using a continuous hinge pin makes this process even easier than it shows in the pictures, because you can stick it right to the pin instead of having to get it stuck in exactly the right place to bridge the gap. Also ripped off from Paul.
« Reply #10 on: July 11, 2013, 04:54:07 AM »
I always used one continuous piece until I was in Hungary and Ted retaped my hinge-line while I was working on other things. He told me that he does not cover the hinges on his planes and that is how he did mine....I didn't notice any difference when I flew it again. Now, I have some planes that will not fly without tape on the hinges and others that fly just fine with or without it. I guess there are a lot of variables to deal with...
Derek
« Reply #11 on: July 11, 2013, 05:59:59 AM »
Great input, thanks guys!
