CLICK HERE--><--CLICK HERE
High oil content
Started by Rick's friend Steve, September 09, 2026, 03:44:16 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Rick's friend Steve
Why do we use 18%, 22%,28% of oil in our engines? High revving 2-stroke racing dirt bike engines, that spin up at 10k+ RPM, use 3-5% oil mix. With modern AAC and ball bearing engines with tight tolerances, is there a reason to use so much oil?
Has anyone experimented with, say, 5% or 10% oil mixes?
Sad Sad x 1 View List
Perry Rose
18% oil 15% nitro in a YS .60 on a Hatori pipe at 14.5 inches 11 x 8 prop in a 9 pound pattern plane and the engine eats bearings and piston/liners.
Dave_Trible
In part to carry away heat inherent to our engines.  You don't want to see what happens when they don't get enough oil or use oil with very little lubrication ability.  I have a couple $400 RO Jetts here............
Oil is cheaper than engines-never understood why some try NOT to use it.
Peter Klosky
No doubt that team racers, especially interested in fuel economy, have used low oil content in the past.  Perhaps 11%.
Mark wood
What Dave said. 15% oil in methanol is quite low and will run with the provision the engine never runs very lean. 20% oil mixture is more tolerant of lean runs. 28% oil is probably on the really high zone and causes troubles with the glow plug staying hot. 22%-25% is in the zone of high toleration of mixture mistakes. Taking off with a too lean mixture with 15% oil and no way of stopping can be catastrophic. Same situation with 22% is more of a pita.
Another aspect is the lubricity of the oil. The oil that gas engines use is petroleum based and is generally not soluble in methanol. As a result less oil is necessary in ratio-metric terms. As compared to synthetic or bean oils compatible with methanol. There's more to it than just those aspects but that's the ground level view.
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Lauri Malila
What I have found, is that in a modern engine with healthy metallurgy and good quality, the crucial place is conrod small end/wristpin joint. Any other place is happier with much less oil than the typical 20...23%.
Also, fuel cools the engine better than excess oil.
If you experience lower temperatures with more oil, it indicates of other quality issues, hot spots and such.
When I changed to DLC-coated crank- and wrist pins, they stopped wearing and I could safely go to 15-17% oil content, even with low viscosity oils. Going down in oil percentage lowered the running temperature, and more importantly it improved the running quality. Engine reacts much quicker and running symmetry is much better when there is less oil accumulation inside the case.
L
Like Like x 1 Agree Agree x 2 View List
Peter Klosky
The oil accumulation thing is real.  A clear plastic backplate makes for a convincing demo.
jerry v
14 percent oil works fine in the racing engine.
Jerry
Variety is the spice of life.
Lauri Malila
#8
Quote from: Peter Klosky on September 09, 2026, 11:29:00 AMThe oil accumulation thing is real.  A clear plastic backplate makes for a convincing demo.
What you see thtough the backplate is not a mystery itself. The big surprise is that also under those conditions you can have a stagnant wave(s) that burst loose under certain conditions.
That is the main cause for the burp of side mounted engines.
Dave Hull
For folks comparing sport/stunt to F2C fuels running low oil content, know also that the lubricity of the main ingredient--kerosene--has to be considered. Kerosene has FAR more lubricity than methanol.
As far as comparisons to small "industrial" engines and motorcycle engines, I believe that on most of those you are going to find rolling element bearings even on the rod ends. That fundamentally changes your lubrication strategy.
Brett Buck
Quote from: Dave Hull on September 09, 2026, 11:59:46 PMFor folks comparing sport/stunt to F2C fuels running low oil content, know also that the lubricity of the main ingredient--kerosene--has to be considered. Kerosene has FAR more lubricity than methanol.
  Another issue is that a lot of the 50:1 two-stroke oils are not compatible with methanol fuels. Aldrich found some compatible type and made "Magnum" fuel which was reportedly <5%.
   But your point is really the kicker - the lubrication system is so half-assed/rudimentary, and uses poor materials for the job, that you are counting on flooding everything with oil and hoping it goes where you want and lasts long enough.
Trostle
Quote from: Brett Buck on September 10, 2026, 12:11:08 AMAnother issue is that a lot of the 50:1 two-stroke oils are not compatible with methanol fuels. Aldrich found some compatible type and made "Magnum" fuel which was reportedly <5%.
I used that Aldrich "Magnum" fuel and thought it to be very satisfactory.  Less fuel was needed to complete the pattern.  I felt there was more power.  The engine ran cooler.  I did not see any down side to the fuel.
I understood that what others did not like was that their engines felt "dry" after they were run using this fuel.  People felt that the engine was not getting enough lubrication or something like that.  I thought that the "oil was there" (a really neat technical term), it just did not give the "gummy castor oil feel" (another really neat technical term) feel people were used to.  I used only 2 or 3 gallons of this stuff, had no problems during that time, but alas - his fuel was no longer available.
Brett Buck
Quote from: Trostle on September 10, 2026, 08:54:08 AMI used that Aldrich "Magnum" fuel and thought it to be very satisfactory.  Less fuel was needed to complete the pattern.  I felt there was more power.  The engine ran cooler.  I did not see any down side to the fuel.
    Me too, it ran fine and was absurdly easy to clean up afterwards. My problem with it that it was discontinued and I couldn't get reliable supplies. The trick was that Aldrich knew enough to seek out a compatible type of oil - unlike everyone else that tried it, who got 50:1 oil from Wal-Mart that was for gasoline.
QuoteI understood that what others did not like was that their engines felt "dry" after they were run using this fuel.  People felt that the engine was not getting enough lubrication or something like that.  I thought that the "oil was there" (a really neat technical term), it just did not give the "gummy castor oil feel" (another really neat technical term) feel people were used to.  I used only 2 or 3 gallons of this stuff, had no problems during that time, but alas - his fuel was no longer available.
    It's just like everything else - by the time we decide it is good, it has been discontinued.
   Do you guys happen to know what brand the oil was?? Back in my early ,motorcycle and go kart racing days, it also then first time they started introducing gas-a-hol. it was just as hard back then to find straight gas as it is now, but we weren't as educated on what the methanol does to a vehicle's fuel system and related components, and I had read in a magazine about being careful when mixing two stroke fuel because of that. I was frequenting a small motorcycle shop who's owner was a damn good mechanic who was mentored by Don Vesco in his early years and he really knew his stuff. He recommended an oil by Kendall, and on the bottle it had a notation that it was blended to mix well with alcohol and would not separate. I remember testing it in a small bottle that I left standing in the sun, shade and such to see if it would separate and it never showed signs of it. It ran great and "burned" in everything I ran it in. Klotz at the time, and as I think it does now, had some silhouette icons or symbols on a bottle of oil to show what it was compatible for , like motorcycles, snow mobiles, lawn mowers and one that was obviously to me representing a model airplane engine. Those are the only two that I can think off right off hand that I know stated they would work with methanol. In kart racing, guys that ran alky back then ran Klotz for the most part but some did use the Kendal like I was. I just can't remember what the bottle looked like, part number, or anything else about it other that I still have a sticky on my '75 Husqvarna 250WR gas cap I think. I would have to empty out my big shed to get to that bike. I THINK it was something like Kendall GT-1?? I may have to try searching for that. It would be interesting to try it on some of the modern engines.
Brett Buck
Quote from: Dan McEntee on September 10, 2026, 12:50:18 PMDo you guys happen to know what brand the oil was??
   I don't, and like ALL fuel guys, Aldrich was apparently very disinclined to tell us, trying to keep the secret. I have found that to be the case with damn near everyone who makes fuel, there is always some "secret sauce" that is some deep dark thing that they, and only they, know about In fact, he may have told Keith but when I just asked him, long after he stopped making it, he flatly refused.
    I was mad enough during the Red Max incident that I actually got pretty far down the road as far as what "secret super-oil that is really good because we say so and they run it in go-karts so how many gallons do you want?" they were using, but finally realized my precious gift of life was being wasted just out of spite. I told them specifically what was wrong with their castor oil (xylene) and they just argued with me.
    I don't care any more, Powermaster is good enough, but if I was going to look, I would try to find oil manufacturer catalogs from the early 70's and find something that was miscible in methanol and rand at 20:1 to 50:1. None, repeat, none of these hobby operations have their own chemical plants, they farm it out, and its something someone already made.
Mark wood
I simply make my own fuel because I know what is in it. I only know a few things important about fuel, partly out of my history and experience and partly out of what I learned as a powerplant engineer. There really isn't a secret sauce that creates a super blend. Clean pure as you can get Methanol, Nitromethane, Klotz and castor. Oxidizers like propylene oxide can make more power but is hardly necessary for running stunt engines. The blend I use in IC CL is the same basic blend I've used in IC RC helicopters and airplanes. 22% oil, 10% nitro, remainder methanol.  One can get by with less oil but, as I referred to earlier lean runs tend to melt down with oil ratios less than 20%.
My experience with production fuels are varied and the consistency has varied. Try one and it works for a long time then one day it doesn't. Ask questions like how much oil do you use, did you change the ratio recently, what oil do you use often result in nebulas or sarcastic responses and me going back to what I know works. There isn't any reason the blend should be a secret. But then the fuel is  commodity that was competitive so each manufacturer had to have the secret sauce in their fuel otherwise how could there's be "special" making them more "valuable".
One of the things I often found was when a production fuel was kind of dicey, adding a couple percent of oil to it made it become reliable. Fuel cost is function of the component cost nitro being the most expense, oil the second and methanol the least expense means cutting oil is a easy target to cost cutting. That is verifiable by using the above test method. With this experience, again I go back to simply controlling the quality myself. I know for a fact, I am not alone.
frank williams
I'm pretty sure that GMA got his lube advice from a gentleman named Bert Streigler.  He was a Shell chemist.  I think the oil was an early turbine oil.  Bert has passed away.  I think he also advised Ritch's Brew.
The GMA fuel was neat .... after a couple of runs your ST46 sounded like a coffee can full of marbles.  It didn't seem to be a bad thing, just "different".  Only ran a couple of cans of it.  I don't know what the % content was, but for sure low.
realSteveSmith
https://www.redlineoil.com/two-cycle-alcohol-oil
-Mixes with alcohol and/or nitromethane for karting, model airplanes, etc.
-Excellent cleanliness, lubrication and scuff protection -- use at leaner ratios than with a gasoline two-stroke product
-For premix with E-85, popular with rotary road race applications
https://www.redlineoil.com/Content/files/tech/Two-Stroke%20TR%203-05.pdf
AMA 175438
Rick's friend Steve
I've been using 18% synthetic oil in pipe engines and 16% oil in big Stalkers (66s and 76s). I've found the engines run super reliably and don't seem to be hurting.
So many things in our hobby are explained with "we've done it this way for decades". Everyone told me I had to use 22.5% oil, 50/50 castor/synthetic(the GMA mix). When I tried running OS 40VF on 18% all synthetic, the engine became super consistent, but people told me it would destroy the engine. 15 years later, the same engine still ran like a champ. How much of this is our hobby lore, and how much of it is practical knowledge?
Brett Buck
Quote from: Steve from Boston on September 10, 2026, 07:31:05 PMWhen I tried running OS 40VF on 18% all synthetic, the engine became super consistent, but people told me it would destroy the engine. 15 years later, the same engine still ran like a champ. How much of this is our hobby lore, and how much of it is practical knowledge?
   It's about 50/50 but the "lore" is 99.9999% bullshit.   But you have to consider that the engines themselves are nothing like what they were back in the day, either. You really did need a lot of oil to keep your Fox running right, and, sometimes adding 5% castor oil to a Fox was better than adding 5% nitro. The reason so many people still buy the BS is that *many people still haven't noticed any change* and still try to run these old 50's engines. The other big issue is that you can't compete with the supposed "good old days" where all these justifiable famous names from the ancient past did their thing. Paul, David, Orestes, etc, have *vastly* better records than any of the old Masters, by a huge margin. Somehow, that doesn't count for anything and they get very little credit compared to the 50's/60's.
    I have run the same 17% oil fuel almost exclusively for 30+ years with no issues. Powermaster "Air" straight out of the can.
Like Like x 1 View List
BillLee
Quote from: frank williams on September 10, 2026, 06:44:56 PMI'm pretty sure that GMA got his lube advice from a gentleman named Bert Streigler.  He was a Shell chemist.  I think the oil was an early turbine oil.  Bert has passed away.  I think he also advised Ritch's Brew.
Shell: no
Conoco: yes
(Names as of  'back then. When Shell and Conocowere distinct entities.)
Bill Lee
AMA 20018
Brian Hampton
Quote from: frank williams on September 10, 2026, 06:44:56 PMI think the oil was an early turbine oil.
That's what I've been using in my fuels (Mobil Jet Oil 2) which mixes perfectly in methanol and never settles out. Its only downside is that it has a brownish dye that can discolour finishes, plastic tanks or whatever. A better alternative is Eastman 2380 turbine oil which doesn't have any dye. Turbine oils are actually an EP gear oil because, in a turbine engine, the sump is the gearbox itself. Also the oil is polarised (similar to castor) meaning it sticks to metal surfaces and eliminates rusting.
doug coursey
Quote from: Brett Buck on September 10, 2026, 07:34:40 PMIt's about 50/50 but the "lore" is 99.9999% bullshit.   But you have to consider that the engines themselves are nothing like what they were back in the day, either. You really did need a lot of oil to keep your Fox running right, and, sometimes adding 5% castor oil to a Fox was better than adding 5% nitro. The reason so many people still buy the BS is that *many people still haven't noticed any change* and still try to run these old 50's engines. The other big issue is that you can't compete with the supposed "good old days" where all these justifiable famous names from the ancient past did their thing. Paul, David, Orestes, etc, have *vastly* better records than any of the old Masters, by a huge margin. Somehow, that doesn't count for anything and they get very little credit compared to the 50's/60's.
I HAVE A COUPLE OF JETT MOTORS a 40 re stunt and a 51 re stunt that are new that i havnt run yet  what % of oil and nitro would you suggest the 51 will be on a pipe and the 40 on a jett header with a muffled end
AMA 21449
Brett Buck
Quote from: doug coursey on September 11, 2026, 05:21:56 AMI HAVE A COUPLE OF JETT MOTORS a 40 re stunt and a 51 re stunt that are new that i havnt run yet  what % of oil and nitro would you suggest the 51 will be on a pipe and the 40 on a jett header with a muffled end
   I would recommend Powermaster "Air", 10% nitro. I don't have a setup for either engine, but that will be a good baseline fuel.
doug coursey
Quote from: Brett Buck on September 11, 2026, 09:04:46 AMI would recommend Powermaster "Air", 10% nitro. I don't have a setup for either engine, but that will be a good baseline fuel.
they have 2 10% airplane fuels with 18% oil one all synthetic and one half syn and half castor,i dont imagine you would need any castor with the RO jett engines
AMA 21449
