  • July 18, 2025, 08:21:34 AM
Author Topic: ...wrinkles??  (Read 1036 times)
Offline Bootlegger
...wrinkles??
« on: March 27, 2013, 03:25:36 PM »
 I am using poly span for covering on a lot of models, and it has wrinkles in it as it comes off the tube.
 Does anyone have suggestions as to how to remove the wrinkles?
 I can't iron the span as this will shrink it, so please let the suggestions fly...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Paul Wood
Re: ...wrinkles??
« Reply #1 on: March 27, 2013, 03:53:39 PM »
Gil,
I would just apply it while stretching out as much of the wrinkles as I could.  The heat shrinking should remove any wrinkles left.
Offline bob whitney
Re: ...wrinkles??
« Reply #2 on: March 27, 2013, 07:53:54 PM »
  i am in the middle of building a P-30 rubber free flight that needs to be covered with Jap tissue ,u cant use any water on it until it is stuck down..  i asked one of my FF buddys how he dose it and he said he use's a glue stick  rub the stick all around the edges and then rub the tissue down and pull tight then do the dope thing . i am going to try it on my next poly span job .will report on how it works
rad racer
Offline Mike Keville
Re: ...wrinkles??
« Reply #3 on: March 27, 2013, 08:01:39 PM »
Bob:  If using Japanese tissue, once it's adhered, give it a light misting of isopropyl (rubbing) alcohol to shrink it.  Then dust on a few coats of hair spray (Aqua Net is preferred) or Krylon crystal clear.  Works well of rubber-powered Free Flights.
Re: ...wrinkles??
« Reply #4 on: March 27, 2013, 08:16:34 PM »
Gil,
 Yep, just pull any wrinkles as snug as you can while attaching the covering and you can shrink them out later when you apply the heat. You should be pulling the covering nice and snug as you attach it anyway, you don't want to count on the heat to do all the work. y1
