  • July 18, 2025, 06:32:37 AM
Author Topic: Hey RANDY POWELL..I found my photo of Lew McFarlands Akro?  (Read 1906 times)
Offline Shultzie
« on: April 17, 2007, 10:52:52 AM »
A while back, someone was asking for a photo of Lew McFarlands Akro? Was it you RANDY...
I took this one with Jack Sheeks Fly-baby in background at the nats...a million years ago.
Don Shultz
Re: Hey RANDY POWELL..I found my photo of Lew McFarlands Akro?
« Reply #1 on: April 17, 2007, 02:31:10 PM »
Don,
Yea, that was me. Thanks for the picture.
Hey Bob, does the AMA have plans available? What, Pond?
Offline Shultzie
« Reply #2 on: April 17, 2007, 05:25:57 PM »
Wow Bob Hunt.....Randy!
I'll let you put your noggins together on this....
Randy... Bob foam wings are truly art. Bob made one for my old FAI Avenger. Gads that model flew so much better than the first 35 sized Avenger which was a multi-ribbed fattened up ala' Bob Gialdini wing design. It HAD TO BE THAT GREAT HUNT WING THAT MADE THE FAI version fly so well.
« Last Edit: April 24, 2007, 03:49:00 PM by Shultzie »
Don Shultz
« Reply #3 on: April 17, 2007, 10:43:25 PM »
Ya know, Shultzie, I may build an Avenger just to spite you.
Offline Shultzie
« Reply #4 on: April 18, 2007, 11:57:04 AM »
LL~ LL~WOW~! Randy, Randy....RANDY! Waaay to razzz-n-jazz!
As anyone can tell from looking carefully at my Avenger plan....just how much I was and still am today a dedicated and died in the balsa dust, BOB GIALDINI ADVOCATE!
From the get go time I first read the beautifully written, and illustrated Olympic article of Bob's in that old AAM issue.
I CAN ASSURE YOU that article to this old Smotzie....was the ALPA-N'-OMEGA..STUNT ARTICLE OF BIBLICAL PURPORTIONS. Talk about instant SALVATION! H^^
One photograph in a magazine showing Bob holding his amazing STING RAY above his head...and next to him was Russia's king of stunt...holding his famous "Spacehound" above his head.
At that very instant.....I KNEW THAT I HAD TO BUILD A STING RAY for the 1967 season.
How innocent and nieve' to believe that I had the skills to tackle such a project.
 After calling AAM and AMA I was gave me his address and phone number.  My long distance telephone bill was proof enough for Bob Gialdini to consider me (by todays standards) a rabid STUNT-STALKER!
During the process of building that first Sting Ray...I would bet I called him at least a half dozen times with all kinds of seemingly foolish questions.
 He was my gurrruuuuu of stunt and believe me...when I say I took that phone and went to his mountain top many, many times.
In the air...the Sting Ray will always remain my favorite model....
rock steady on the lines and its ability to cut through dirty wind turbulance or dead air vortex on multi-loops etc without excessive rock-n-rollin on the lines.
The Ray had very little light line pull...no rudder offset except for an airfoiled vert. tail but still held out there through even the lowest and highest wind situations.
Best of all....although a really clean slippery looking model (perhaps due to the rather tight restriction on both the Merco and later on my OS 35 engines, an effective muffler pressure & a good tank design???)
I didn't have to place and position my loops too far into the wind to keep the wind from winding up model speed.
The only downside of my Sting Rays...was the trike gear & inward swept wind gear location, plus the nose gear position was quite far aft.
 If you looked at the SMALL FOOTPRINT on the ground of this model...you will see that all three gears are placed noticably close together...(which perhaps enhances that great in the air  flying performance but SUDDENLY NOW  takes a new skill in learning how to take-off and land this trike platform with precision.
Bob mentioned that the Sting Ray should always be landed at considerable higher speeds, while the wing still has some stabilizing factors.
(Often trike gears...telegraph to the flyer and the judges EXACTLY when ground contact is made with that tell-tale wibble-wobble C.G. shift thang')
But on the Sting Ray......nothing is as beautiful to behold and watch as
 that smoooooooooooooooth transision of the Sting Ray desends  from the air to the ground.
 Also if done correctly, is just one constant smoooooooth touchdown without even the slightest wiggle...as that small landing gear footprint and the radical inward tapered main landing gear wires , do their thing by absorbing  any landing shock with that soft spring action.
BUT MISS TIME THE TOUCHDOWN...LOOOOOOK OUT!!!
BOTTOM LINE:
 On my Avenger...I wanted a gear that I could fly off grass, gravel or tarmac.
The Sting Ray must have been designed and  made for smoooth tarmac flying only...GRASS FIELDS WERE ALWAYS A NIGHTMARE.
Missing the wind..on landing and then trying to land that StingRay with too little airspeed...again proved often another nightmare. That inward sweep and soft springy gear would flex and rebound...causing one wing and then the other to dipity-doo back and forth until the model stopped rolling. Funnier yet..was to see my StingRays...sitting in the flight line up during contests in sizable wind. While all the models in the line up were just sitting there, still as a rock. But in contrast, that Sting Ray of mine...looked like it was litterally ALIVE...as it sat there on the tarmac...doing a little wiggleee-rock and roll thing with even the teeniest puff on wind on that tail.   In the end...proving that who ever chooses to build the Sting Ray with that trike gear design, must grasp the ART OF LANDINGS AND TAKEOFFS...all over again.
However Bob Gialdini helped me improve the landing gear on my second Sting Ray. I simply slipped some tubing over the main landing gear wire before bending. This improved the stiffness and reduced the wobbleeees'
Randy and gang...Sorry for the rant tanget about trike gears! They do have their advantages and downsides. The choice seem clear as mud at times? ;D
RANDY! THANKS! for the razz...
but after looking at that beautiful pencil sketch of your new design...THAT MODEL YOU SKETCHED IS PURE AND SIMPLE...GREAT STUNTMODEL SKYART.
Hummmm? Just for spite....I wonder if I could return the spite and build it before you do.
However...
Knowing your amazing ability to build almost as fast as SPARKY!!! THAT COULD NEVER HAPPEN TO THIS OLD TOOT IN A MILLION YEARS! **)
Don Shultz
« Reply #5 on: April 18, 2007, 12:41:23 PM »
You go, Donny!
« Reply #6 on: April 23, 2007, 04:12:52 PM »
Looks and sounds as if the McFarland Spinks Akromaster foamer kit idea, and the large sized model idea, was a bit ahead of it's time.  In the eighties I bet you could've sold a bit more than ten, Bob!
As most of you have probably figured out, the musician, artist, professional aerospace model builder, and super stunt builder, flyer Don Shultz built some really beautifully crafted and finished models. I remember the Stingrays from the 60's that he built and they were right up there with the master's Gierke, Kostecky, Werwage, etc as far as finish. I also remember he barely missed the fly-off cut one year, by one point! That was the top TEN, back then.
So when you read all about how he is a kinda notso good at it builder, he is just bein' shy...
Chris...
« Reply #7 on: April 23, 2007, 07:07:19 PM »
Don showed up at a contest at Boeing Space Center back the early 80s with a metallic red, white and blue Chipmunk. It was one of the best finished planes I'd ever seen. That plane inspired me for a lot of years.
Offline Shultzie
« Reply #8 on: April 24, 2007, 09:54:37 AM »
HEY RANDY AND CHRIS.......THANKS FOR THE ROSES!
Uhhhhhhhhh? However, after looking at both your beautiful models on stunthanger.....and lurking on other model websites.....That old saying:
"One is only as good as their last gig or stunt model!
Just the thought to build another stunter on even an equal artistical' plain-plane as either one of you....
Well, Even the thought of building another model near the same level of beauty and expertise that I see in both your models---
NOT ONLY BOGGLES MY MIND.....BUT BUNCHES MY BRITCHES INDEED!
A sobering and humbling thought indeed!
Hey! I just saw Paul Walkers model on Flying Lines this morn. check this out!
I can't wait to see the rest of them.
I took autistical' coppin; and just had to post a couple
I just saw that beautiful model on your post...so let me show your gift of not only desiging beautiful models but also one that now flys equally well?
« Last Edit: April 24, 2007, 03:45:30 PM by Shultzie »
Don Shultz
« Reply #9 on: April 24, 2007, 02:26:47 PM »
Trust me, Shultzie, you do just fine.
