Doug - Even my Gieseke Nobler at the US Nats had them.. I managed to hide them really well - unless you were looking for it.. you may not have noticed.
I did try them near the flap also - I found no additional improvement. For me, thats what It has ALWAYS been about, improvement. I cannot tell you how many flights I've had where I experimented. Using the carbon fiber and some tweezers, and zap, takes all of 2 minutes to adjust them. - Obviously I wouldnt do it with a nice painted model. however once a model reaches a certain " age " you stop thinking about its looks..
I tried literally hundreds .. ( well maybe not 100's . but an alot. ) of seperate configurations. Initally they were all along the wing, just as you see it in your diagram. Over time - some broke off.. and performance didnt seem to be effected. So I would start to expeirment with different configurations. The first sets were rather crude by what I do today - 1/ 64 ply, in a triangle shape. I even went as large as 1/2 " long !
I tried them infront of the flaps, on the fuse, on the tail, on the Stab, on the rudder.. I tried the Bear Plates, on and off.. had VGS on and around them.. Each time making notes on performance - compared to the baseline.
Over time.. I found I could run fewer and fewer.. in 2004 I was down to 1 set at the root and 1 set at the tips.. always thinking that I needed them at the tips.. Whenever I removed it.. It was in the back of my mind - Im sure there was a difference.. however it was not something I could quantify. Even the Bomber had 2 sets ..
As mentioned the 2 at the tips - I never totally convinced myself that they were working.. or not working.. there was such a small difference I just ran them for maybe 4 years in that configuration. Eventually I settled on 1 pair near the Root.. but.. 6" inward. I found too close to the wing I get less effectivness..I can only reason that this is due to the fact there is not enough of the wing being energized.
Perhaps this explanation is why I found such a little alteration in the early days from running 2 sets.. the first set was always alot closer to the Root, compared to todays versions.
I suspect you could put them in the middle of the wing and get similar performance.. I chose to put it there, Mainly to help reduce the prop wash into the Stab. How good does it work ? I have no idea.. I would have to move them to more in the middle.. perhaps I will experiement with that later - however for now its working perfectly.
For me..... the Idea of adding 1 pair of VG's is done before the model is even test flown - I put it in the same catagory as sealing hinglines.. a performance improvement device or PID.
Incidently, I find it impossible.. to stall no matter now hard I bang the corner.. Not like what Matts talking about. Im not just talking about my Nobler, remember I do fly normal comp spec planes usually..
I have also never experienced "dead" spots of air.. like what happened to your model Doug ( I'm not having any sort of go at you mate.. that was 1 in 1000.. please..very unfortunatly and sorry to see.. ) I postulate that the even if the model does hit a "dead patch" there is still plenty of residual Vortex airflow to keep the model in the air.. Think of it.. like a bird facing into the wind.. they are stopped, but are not dropping becasue of the airflow moving over the wings its equal to normal lift at forward speed.
I suspect I get a similar thing happening with the addition of VG's - The spinning Vortex by nature would take longer to exit the wing compared to normal flight.
I also notice flying in strong winds, I dont get knocked around as much, and almost NEVER have the model suddenly drop out of the sky downwind in a landing. On that note.. landing with VG's is difficult, you need to really LAND it.. whereas a model without, you can let it drop naturally.
I guess the bottom line of all this is simple - Like anything in our sport try it for yourself, and make your own assessments. I can supply any drawings or photo's of how I set my system up. The carbon I use is from APC its .04 or .03 thickness Carbon laminate. Cut, sanded and glued on.
Doug Id be very interested to hear your feedback if you wanted to try them. It wont radically alter your engine setup .. might just load it up a little more.. more pitch or more revs.. Let me know if you need some more info.
You can see them on my Nats Gieseke Nobler.. from this angle.
