  • July 17, 2025, 10:00:24 PM
Author Topic: Here is some pictures of what I am working on.  (Read 2077 times)
« on: November 11, 2006, 12:14:24 PM »
Ryan and I are building two Scrappers.
Here are the pictures of mine. I will let Ryan post pictures of his.
I got the rib template from my flying buddy Kreth. He cut out the fuse and set the engine spacing up for my power house Fox .25. Can you say SLOOOW?
It should be a kick in the pants. **)
« Last Edit: November 11, 2006, 03:54:55 PM by Robert Storick »
Offline Bill Gruby
Re: Here is some pictures of what I am working on.
« Reply #1 on: November 11, 2006, 12:26:35 PM »
Paul;
Nice work so far, Istill like the Twist Stang though.
Bill Gruby y1 y1 y1 y1 y1 y1
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #2 on: November 11, 2006, 12:44:41 PM »
With little tiny holes for the leadout wire there is no way to adjust your leadouts. Also you do not want your leadouts to be 3 inches apart at the wingtip . 1 inch would be better.A friend of mine who is on here a lot forgot the holes for the leadout wire on a D-tube wing. That was fun to fix.Right EV Just though I would mention it before you covered the wing
« Reply #3 on: November 11, 2006, 01:43:33 PM »
Good point Ed, I will fix it.
Thanks!
« Reply #4 on: November 11, 2006, 10:35:31 PM »
Where does the fuel tank go? I figured the tank was inside the wing, but don't see anyplace to put it (yet).  %^ Steve
« Reply #5 on: November 12, 2006, 08:30:13 AM »
Yup the tank will  be in the wing with the tubes poking out.
Sheeting the LE and will cover in "silk ch-fawn".
(Not sure on the spelling, but that is how it sounds.) :!
 AP^ vs  AP^
Ryan vs Dad
Offline Art Zehner
  • Art Zehner
« Reply #6 on: November 12, 2006, 01:24:13 PM »
  Looks great Paul.  Do you have an extra set of plans or know where to get them.
AMA 814545
« Reply #7 on: November 12, 2006, 02:36:11 PM »
Hey Art,
I will see if I can get a copy for you from Kreth. The wing is built different then what the plans show. The ribs are the same, just the spar is different.
It is a real tough wing built the way the picture shows. Kreth made a real slick jig for it. Just slip in the ribs and the spar in along with the LE and TE then tack it. Pull the wing out of the jig in 5 mins. y1
I think you could almost drive a 16 Penny nail with it.
« Reply #8 on: November 12, 2006, 04:09:58 PM »
Paul, assuming you're putting a metal tank in the Scrapper...Fit a brass or steel washer over each tube, down as tight to the tank as you can, and re-solder. This was the only way I found (in the '60's) to prevent the tubes from coming loose and leaking. If you don't do this, you will regret it!  y1 Steve
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #9 on: November 12, 2006, 06:27:06 PM »
Looks pretty mean Paul.  I bet it will be a hoot.
Silk SheFawn  huh?   I bet it will smell purty.   ~>
Keep em coming.
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
« Reply #10 on: November 12, 2006, 07:14:53 PM »
Ahhhhh, the sweet smell of castor!!! y1
Offline Richard Grogan
« Reply #11 on: November 13, 2006, 01:39:29 AM »
Keep em coming.
Chiffon?? OOOHH-LALA!
Long Live the CL Crowd!
                  AMA 85745
Offline Zuriel Armstrong
« Reply #12 on: November 13, 2006, 08:17:41 AM »
Hey Paul,
I guess you are tying to make me feel guilty for not getting anything done so far...well it's working >:D
Zuriel Armstrong
AMA 20932
« Reply #13 on: November 13, 2006, 08:42:55 AM »
Hey Paul,
Naw... I know you are taking care of business.
Stuff Happens, and you deal with it.
