  • June 26, 2025, 07:23:27 AM
Author Topic: Reno Air Races  (Read 2248 times)
Offline Matt Colan
Reno Air Races
« on: September 24, 2009, 06:36:18 PM »
Not sure how many know as this is now a few days old, but anyway...Strega wins again for the I-don't-know-how-manyth time!!!! Rare Bear was second and Czech Mate was 3rd. The final race speed was a record 491mph!
Source: www.mustangsmustangs.com
I only remembered Reno after reading Rare Bear's article in Air and Space.  His new scheme would look great on a stunter, as do a lot of Air racers.
« Last Edit: September 27, 2009, 06:08:25 AM by Matt Colan »
Offline billbyles
Re: Reno Air Races
« Reply #1 on: September 24, 2009, 08:44:00 PM »
Source: www.mustangmustangs.com
I posted this on the other forum just as further information on the Reno Air Racers:
Actually, a few years back, the record race speed was set by the
P-51 Dago Red at 507.105 mph and the qualifying speed record at Reno was also set by Dago Red at 497.797 mph. Dago Red also holds the 15 km low-level piston-powered propeller-driven speed record at 517.323 mph. Dago has won the Gold at Reno 6 times.
Strega is a formidable airplane and is extremely well-flown by the 22 year old son of Steve Hinton (himself a legend among warbird people). Strega is beautifully done, fast, and reliable.
Rare Bear (2nd in the Gold Race this year), flown by John Penney, was suffering engine problems this year and could not put the power to it. Still not too bad to finish 2nd in that fast company.
Frank Taylor, the original builder of the Dago Red racer in 1981, re-acquired the airplane this year. We are in the process of restoring Dago to the condition it was in when Frank set the speed records and expect to take Dago to Reno in 2010. Additionally, Frank plans to go after the 3 km low-level piston-powered propeller-driven speed record currently held by Rare Bear at 528 mph, as well as attempting to up the speed for the 15 km low-level piston-powered propeller-driven record currently held by Dago Red.
Dago is sitting in a hangar at Chino along with the 53' race trailer that serves as a machine shop and parts hauler at the air races. Work has been progressing on the airplane. The website for Dago is www.dagored.org if you are interested.
Bill Byles
AMA 20913
So. Cal.
Re: Reno Air Races
« Reply #2 on: September 25, 2009, 12:17:43 AM »
Thanks for the info, guys!
Mongo
Offline the original Steve Smith
  • Fly Stunt!
Re: Reno Air Races
« Reply #3 on: September 26, 2009, 07:33:52 PM »
Just checked out the site and the url is actually www.mustangsmustangs.com
AMA 2112
Offline Matt Colan
Re: Reno Air Races
« Reply #4 on: September 27, 2009, 06:08:07 AM »
Whoops missed the first "s".  Original post has been edited.  That website is great for anybody who is a P-51 fan, or even a Warbird enthusiast, it's really nice.
Re: Reno Air Races
« Reply #5 on: October 03, 2009, 12:37:53 AM »
Hi Matt,
Great race. I was lucky enough to go for Friday through Sunday and the Unlimited action was fast and very dramatic. There were so many competitive airplanes that it made witnessing the action fun.
Rare Bear had a new engine that was a last minute replacement which was a mostly stock power and blower section with their trademark "slow nosecase" prop reduction gearbox replacing the usual faster geared one. This engine wa way down on power compared to their full race engines and the teams new liquid boiler oil cooling system reduced the drag enough for them to run competitively even with a 600 to 700 hp defecit. They "broke in" the engine through the week, with test flights and race heats showing incrimental speed improvements showing their increasing the power as the week progressed.
Strega had a super hot Mike Nixon racing Merlin with all the trick set-up running as well as ever. Stevo Hinton put the airplane where he wanted it (except for one pylon cut on Saturday that put Voodoo's 486mph heat speed on the pole for Sunday's Gold) and showed that he could win if the engine held.
Voodoo had an engine by a guy they nicknamed Earl, it was his first all out race Merlin and was done in long time Merlin builder Jack Hovey's shop. Will Witeside is the new pilot and he did a fine job keeping out of trouble at speeds as fast as Strega, when necessary.
Dan Martin's Ridge Runner III looks stock in the off season, but it had a lot of full race streamlining features that are invisible plus the clipped wings and Dago red type scoop and doghouse along with the full race Mike Barrow Merlin. They had a problem with too tight clearances on the piston pins causing a failure of the tops and skirts, one was real bad and all the rest were following it. Mike took the removed heads and banks back to his shop, put a new liner in one, honed all the rest and replaced all of the piston rings in last years pistons and pins, then drove back to Reno where the crew reassembled the engine and ran a 477mph average on Saturday's exciting heat.
The Moore's Czech Mate Yak runs a Pratt&Whitney R-2800 that is said to be a CB-3 low altitude airliner engine but with a lot of hybriding to select the best parts for the 5000 foot elevation course at Reno. They were timed doing 470+ laps and were beating the heck out of theSuper Sea Fury Dreadnought.
This sets the stage for Sunday's start, which was a mini race in itself. Even more than usual. Here the start was a picture perfect release as the T-33 pace plane pulled off earlty enough to let the racers have their full head. The pole sitter Voodoo was wings level, shallow dive for pylon 4, way at the back of the course. Strega was outside and they were wingtip to wingtip in a drag race that was about 5 miles long to that first turn where the airplanes are very small.
I knew whoever came out ahead in the turn would be the winner. Will held his line and told a good friend of mine that Stevo pinched him into the turn and cut him off. Strega was ahead by about a half a length when they were seen banking onto the back of the course, and that was it. He held the lead and kept it wicked up for several laps doing three at over 500 mph.
Rare Bear ran up and past RRIII on the drag race, and closed 3/4 of a mile of the leaders on the start, but even though he was able to hold this interval John Penney couldn't gain any more ground and was treated with one lap at 499 mph.
Voodoo ran close to Strega but didn't have the power that Strega was running, or chose to hold off til later! Will flew well, but encountered wake at least twice following the leader that caused him to roll and correct to re-establich himself on the course and in doing so lost a bit of ground. inally he had an engine problem that forced him to mayday out on lap 6. Too bad, it was a valiant effort and really showed what the pilot and crew can do with this racer when a fine racing mill is running well.
The Yak passed RRIII in some of the best racing seen, as well as Matt Jackson flying a low groove, tight line in Dreadnought that had it going as fast as 460mph. This on a borrowed engine pulling enough power to stay in the hunt, yet fly it home on Monday.
Fury and Riff Raff were racing for a while but Riff raff was using a lot of power and Hoot Gibson knows his way around the course and traffic.
Howard pardue flew his retirement race in his super fast, stock XF8F-1 at a speed that looked like he was standing still but he was running 400mph laps!
So it was a pretty good, record Sunday Gold race speed. They were good, but they didn't break any Dago Red records so next year, LOOK OUT! Go Dago Red!!!
Chris...
Offline Matt Colan
Re: Reno Air Races
« Reply #6 on: October 03, 2009, 06:48:08 AM »
Hi Chris,
I'm a Strega fan myself, but really any Mustang that wins I'm a fan of.
Too bad they don't televise this anymore.  Grandpa taped the 1998 Races on ESPN, and that was an exciting gold race with Dago Red winning I believe
Offline billbyles
Re: Reno Air Races
« Reply #7 on: October 03, 2009, 07:36:38 AM »
Hi Matt,
Chris...
Hi Chris,
Thanks for the excellent detailed description of the Gold race.  That is the kind of info you can only get by being there and being knowledgeable as one who has raced at Reno as you have.
Some comments about Dreadnought for those who may not know: Except for a couple of engine change-outs due to failures, Dreadnought has not been altered since 1984 and is a Hawker Sea Fury with original size full-span wings, dual-control, full double canopy, two-cockpit airplane with only a few minor aerodynamic alterations.  It is, of course, running the Pratt & Whitney R-4360 four-row, 28 cylinder engine that Frank Sanders and all of us on the crew in 1983 installed.  After Dreadnought won the Gold in 1983, failed an engine in 1984, was 2nd in the Gold in 1985 due to a cut pylon, and won again in 1986, Frank Sanders decided that he had proved a point and moved on to other projects choosing to race Dreadnought in its then current form rather than pursuing a course of continual modification to improve its speed.  It is racing in the same configuration as it was in 1984.
The R-4360 engine that Frank built in 1985 raced for 15 years without a problem  before it finally failed; probably a record for engine longevity for airplanes running in the Gold race and rarely finishing worse than 2nd or 3rd for many years.
Hey Chris,  I finished school on August 31 so when are we going flying?  Let me know.
Bill Byles
AMA 20913
So. Cal.
Re: Reno Air Races
« Reply #8 on: October 03, 2009, 11:56:01 PM »
Hi Matt,
I'm with you there, Mustangs are very pretty and exciting. I am a long time Bearcat guy because my Dad was good friends with then owner/pilot Lyle Shelton, and when I was your age I met him back in 1970!
Now my longtime best friend and brother-in-law owns Dago Red, so I naturally am rooting for them.
Bill,
I'm going to Tucson for the 1/2 A Profile Scale contest next weekend with Michael. I'm sick in bed right now. I'm hoping for a Kaos first flight in two weeks.
Chris...
