  • June 25, 2025, 01:51:39 AM
Author Topic: ...muffler...  (Read 1579 times)
Offline Bootlegger
...muffler...
« on: March 13, 2011, 08:32:10 AM »
  :!    Guy's I need a muffler for a S T 60 that can be mounted thru the center web of the exhaust.
  It doesn't have the muffler ears on each side of the exhaust stack.  # #^
              Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Ward Van Duzer
Re: ...muffler...
« Reply #1 on: March 13, 2011, 12:29:34 PM »
Call Aero-Products!
W.
Re: ...muffler...
« Reply #2 on: March 13, 2011, 01:19:44 PM »
Hi Gil,
I'm sure Randy has something to fix you up!
Leonard Neumann also has an adapter to use on the ST (and other engines with the hole for the R/C butterfly in the exhaust) that takes a "normal" ST tongue or tube muffler.  The adapter bolts into the hole, and has "ears" to hold the muffler.
Scott Riese also makes tongue mufflers for this.
Offline dennis lipsett
Re: ...muffler...
« Reply #3 on: March 13, 2011, 05:14:16 PM »
The center hole is not for a muffler but an exhaust baffle. Common in the 60/70 period it closed with the throttle to keep the plug hot to avoid flame outs. That said there are no mufflers made with a single attachment point for any engine. Your going to have to get a strap on or JB weld some brass tubing along side the exhaust stacks to accomodate the muffler bolts.
Dennis
Re: ...muffler...
« Reply #4 on: March 13, 2011, 06:26:03 PM »
Dennis you are incorect. I have one I got from Randy Smith at Aero for my ST/46' I did tap the hole in the center of the exhaust for a larger thread .
Re: ...muffler...
« Reply #5 on: March 13, 2011, 07:42:02 PM »
Dennis
Aw... Dennis.  You just haven't kept up! LOL!!  Of course the center hole isn't "for" a muffler, but that don't mean no one makes mufflers to mount that way.  Don't make it sound like I don't know what I'm talking about....  ;D
Like I said, everything from tongues with holes in the center to "adapters" to mount in the "center hole" and then mount a regular bolt on muffler.  I have both styles and have used the "adapter" in contest work with a McCoy Red Head .40. ;D
Big Bear
Offline Bootlegger
Re: ...muffler...
« Reply #6 on: March 14, 2011, 11:23:44 AM »
 H^^   Big Bear I sent ya' a P/M..   Thanks, Gil
Gil Causey
AMA# 6964
Offline Joseph Patterson
  • AMA member- Supporter
Re: ...muffler...
« Reply #7 on: March 15, 2011, 07:30:11 AM »
     Gil, I believe Art Adamasin also made/makes an adapter to mount on the center exhaust baffle threads, I saw it mounted on an ST60 on EBay. Might check w/ Byron Barker also.
Re: ...muffler...
« Reply #8 on: March 15, 2011, 08:09:05 AM »
Back at ya, Bootlegger! ;D
Big Bear
