  • July 04, 2025, 07:06:39 PM
Author Topic: Help with a vendor  (Read 1569 times)
Offline peabody
Help with a vendor
« on: June 20, 2022, 06:34:53 PM »
I seem to have 2 5 ounce hypodermic looking fuelers....both pretty old.
I'm afraid the heat here in Paradise hastaken a toll.
These fuelers have orange o-rings.
Who sells them?
Offline MikeyPratt
Re: Help with a vendor
« Reply #1 on: June 20, 2022, 06:39:05 PM »
Call Jim Lee or Melvin, they got them.
Mikey
Online James Lee
« Reply #2 on: June 20, 2022, 06:48:37 PM »
The ones I make have a label saying Lee Machine Shop.   accept no substitutes!!   ;D
thanks
Jim
« Reply #3 on: June 20, 2022, 07:10:12 PM »
Not anywhere close to what you have but I have used the ones designed for Bar-B-Q injecting from Walmart.  They are accurate and Cheap!  Well, they were cheap.  They are not the bulb type.  Look like a giant hypodermic needle.
Online James Lee
« Reply #4 on: June 20, 2022, 07:26:46 PM »
Rich
PM sent
thanks
Jim
Offline Perry Rose
« Reply #5 on: June 27, 2022, 05:48:50 AM »
To prolong the life of the "O" ring I put a wrap or two of 1/8" trim tape under it. Also if I don't use it for a couple of weeks the ring shrinks a bit but comes back after a few fuelings.
Offline Wayne Collier
« Reply #6 on: June 27, 2022, 12:13:38 PM »
I get syringes at the feed store. They come in a variety of sizes. Toss and replace when they get gunky or stop working smoothly. Look at them close. Some have ends made for slip on needles and will fit fuel line. Some are have threaded ends and don’t fit fuel lines.
Offline Lyle Spiegel
« Reply #7 on: June 27, 2022, 02:44:10 PM »
Are orange O rings preferable to black?
I have seen the combat guys syringe - they have some type of barbed fitting that attaches to the syringe and provides grip on the fuel tubing.
Where can I find them?
Lyle
Lyle Spiegel AMA 19775
Offline Allen Eshleman
« Reply #8 on: June 30, 2022, 04:06:37 AM »
I found some at Central Tractor Supply.
Offline Reptoid
« Reply #9 on: June 30, 2022, 01:35:08 PM »
Lyle
MBS   http://www.mbsmodelsupply.com/  or Bill Maywald. You can buy them on line from medical supply outlets but usually the minimum is 100 ea.
       Don
       AMA # 3882
Online Jim Hoffman
« Reply #10 on: June 30, 2022, 06:48:16 PM »
O ring color is usually indicative of its material.
I prefer silicone o rings for glow fuel.
BLACK usually indicates Buna O-rings, also known as nitrile or NBR O-rings, offer excellent sealing and mechanical properties at a low cost. Buna O-rings have resistance to common lubricants and are recommended for crude oil, gasoline, propane, petroleum oils and water.
ORANGE is usually silicone
